How many miles to the tank?
Old Aug 10, 2007 | 08:49 PM
  #31
coolslice's Avatar
Well I filled up tonight. Fuel light was on at 366 miles. It took 25.8 gallons to fill up.. 14.1 mpg - All city with AC. Obviously there is a problem with my sender, I basically had 8 more gallons left with my fuel light on. Great...
Old Aug 10, 2007 | 09:51 PM
  #32
GrizzlyAdams's Avatar
I have an 06 Megacab 4x4 with about 34,000 miles. My last trip from New Mexico to California (Sacramento) I got 23 miles per gallon pulling an empty trailer.weighin in about 2500lbs empty. So I got just over 720 to a tank. I have minor mods drop in K&N filter and no silencer.
Old Aug 10, 2007 | 10:32 PM
  #33
JP-4.5's Avatar
Most of my tanks are in the 620-650. Last tank was 693.. I went 35 miles past when the overhead stated 0 miles left DTE. 38.xx gallons went back in. It was 17.8 on that tank. I have got over 700 a few times when I have more highway than around town. 17s for my average and 19s if I have mostly highway miles.
2004.5 QC LB 4x4 with some mods... Likin it...
Old Aug 10, 2007 | 11:59 PM
  #34
TonyB's Avatar
My overall average is 13.79mpg, from day 1. My best was 16.3, twice once was 50% freeway back in May and the other was last year on a straight freeway run to tucson & back. Checked it truck stop to truck stop...same one. I'm pretty confident I can hit 17-18, depending on load & distance. Boy, that'd be nice !
Tony
Old Aug 11, 2007 | 09:11 AM
  #35
dogger's Avatar
My mileage
Originally Posted by VikingDiesel
WHOA, the most I get is 500-550
I get about a 1000 miles to the tank.
But then I have a 56 gallon aftermarket tank. Painful on fillup.
L8r,............dogger
Old Aug 11, 2007 | 10:40 AM
  #36
FMB's Avatar
FMB
I'm a proud member of the 700+ club. I love the vent mod kit. (oh, BTW, that is a very small +)
Old Aug 13, 2007 | 02:23 PM
  #37
paroxysym's Avatar
seriously, what causes that? i filled up with my fuel light on yesterday at 411 miles and it too like 28.2 to top her off... dont get it.
Old Aug 13, 2007 | 02:45 PM
  #38
coolslice's Avatar
All I can tell you is that my truck is set to have the sender replaced in the morning. After filling up last friday night, I have driven only about 20 miles since and my needle has moved well off the peg at the full mark.
Old May 6, 2019 | 01:21 PM
  #39
Mason d's Avatar
Well, I'm at about 360 miles and gauge is almost to "E". I plan to fill up today, but something is obviously wrong. I gave a pretty penny to have the Fass installed and have my in-tank LP switched back to the old style, then the tech took my new style LP after I told him I wanted to keep it. Now I'm stuck with this old style that doesn't work right for whatever reason, and he probably knew all along. I'd like my fuel gauge to be accurate. I think the real story will be told today after I fill up.
Any suggestions?
What's the new style your talking about for the in tank unit
Old May 6, 2019 | 10:09 PM
  #40
StealthDiesel's Avatar
This is a really old thread..
Originally the 2003-04.5 trucks had an external lift pump mounted on the fuel filter canister on the engine.
This external lift pump had a high failure rate as mine did back in 2004. Starting in 2005, Dodge went to an in-tank lift pump which was much more reliable.
Dodge issued a TSB for the external lift pump failure. The TSB was to install an in-tank lift pump and kit. The in-tank lift pump is integrated into the fuel tank canister which replaces
the old style, non-lift pump, fuel tank canister.
It sounds like Coolslice (2004.5 truck) had his external lift pump upgraded to an in-tank lift pump at one time and then he went back to an aftermarket external lift pump, the FASS.
The in-tank lift pump and fuel tank canister is usually removed or modified when going to an aftermarket external lift pump.
The old style fuel tank canister is actually better when using an aftermarket external lift pump.
In Coolslice's case it looks like his new style in-tank lift pump fuel tank canister was removed and the old style fuel tank canister installed.
I hope all that makes sense!
Old May 7, 2019 | 09:43 AM
  #41
Mason d's Avatar
Yes it does thank u very much
flyingd
Jul 31, 2008 09:39 PM
bobg333
14
Jan 13, 2008 09:33 PM
TXlilbro
Jan 12, 2008 05:32 PM
Txwelder
Sep 27, 2007 07:48 PM
joelmopar12
Jan 23, 2006 11:00 AM
