How long will she live
Old May 30, 2006 | 01:06 PM
TE-44's Avatar
I had the #3 injector fail somewhere along my drive back to San Antonio from Houston which resulted in a large mess under the truck. My question is how long can these engines run with only the diesel fuel being the only lubrucation. The dealer only wants to replace the failed injector and replace the 12 quarts of oil that blew out send it on down the road.
Old May 30, 2006 | 02:23 PM
TonyB's Avatar
1st thought: Check oil pressure.
Case in point, my '06 with 4500 miles gets >70PSI (HOT) at 2500 RPM. I don't recall (manual at home) but there are pressure specs at idle and 2500 RPM. IIRC, >45PSI at 2500 RPM, HOT.
If you are <45, HOT, reject the motor. They may be able to put a new oil pump in, but the cam, rod, and main bearing would have too much wear. A new oil pump may, depending upon miles on the motor, improve the situation a little to mask the bearing wear.
How many miles on your rig?
Tony
Old May 30, 2006 | 02:29 PM
TE-44's Avatar
The truck has 30,600 miles as of today, the oil pressure seems to be reading normal on the instrument panel.
Old May 30, 2006 | 05:42 PM
VikingDiesel's Avatar
Wow....I dont know how a lot of your guys have these injector problems, is this part of the drivetrain warranty if the injector goes bad?
Old May 30, 2006 | 06:09 PM
Spooler's Avatar
Don't know if you guys know this but the factory oil pressure gauge isn't worth a crap. The sender senses if it is under a certain pressure(think it was stated on here 5 PSI). The ECM is preprogrammed with what it should read at a certain temp. SOOO, it is a fake gauge. You can do a search on it.
Old May 30, 2006 | 09:24 PM
ckennedy's Avatar
Thats what I have been told (5 psi = normal readout! )
gscoker
16
Feb 17, 2013 01:52 PM
Beast2B
Dec 8, 2009 01:44 PM
I PASS GAS
Oct 12, 2007 10:25 PM
andyr354
Aug 19, 2005 03:43 PM
jeffteel
Nov 1, 2003 09:09 PM
