How Long Can The Engine Idle??
I installed a very high tech high idling device on my truck last night. It's VERY similar to this one:
https://www.dieseltruckresource.com/...gh%20Idler.JPG It holds my engine right at 1200 RPM's. My question is...how long can the engine idle at 1200 RPM's before it starts doing some kind of damage?? |
Re:How Long Can The Engine Idle??
Hmmmm....30 minutes?? 1 hour?? 2 hours?? 3 hours?? Anyone??
That looks similar to that piece of floor molding that worked so well in my truck last winter.
I've heard that 1200 rpm is sufficient to maintain heat in the engine to mitigate any wet-stacking issues etc. How long to idle at 1200rpm? Probably as long as you want, just as long as you don't drain the tank dry. |
Hoss, how about sending that question to Cummins? That would end any speculation and we would all have the answer right from the horses mouth.
Good idea. I'll give that a shot and see what happens.
Update....well, not really an update because I haven't heard back....but I just sent an e-mail to Cummins to see what they say about it. When/if I hear back from them I'll report back what they tell me. :)
Here's something to read while you're waiting (see short term comment #4):
http://dodgeram.info/tsb/2000/cummins01-06-00.htm |
Good read....just a few comments:
To prevent or decrease the risk of this occurring to an engine which frequently idles for long periods of time in arctic temperatures... Prior to shutting off the engine after extended idling (6 hrs) it is important to bring the engine to operating temperature (minimum of 140 degrees) to remove any carbon build up on the valves. Bottom line....that bit of info, while informative, doesn't really apply to me. :) |
Hey Hoss I have and 03' and I have let the Truck Idle for about 15 min. then I put somthing on the the gas pelal to bring up the RPM's to about 1600, after that I ran my Truck for about 1 1/2 hours to 2 hours then the normal low Idle for about 2 minuts, They are ment to run allday at a higher RPM'
I have let mine idle (on a couple of occasions) for as much as 20 minutes at 800 RPM's. I know this isn't good for it though....hence the high idler. I just don't know if it's doing any damage to idle like that for extended periods of time.
I know they'll RUN at higher RPM's. It's the lower RPM's that I think are supposed to do the damage though. Plus...although I haven't experienced this...I would think it would be easy to overheat just sitting there idling for long amounts of time (no air movement). |
Hoss, they're not worried about overheating, they're concerned about "under heating" and sticking the valves.
What temperature would be considered too cold?? Mine usually hangs around 200 degrees after it warms up.
since you live in TX, it doesn't matter. ;D
True.... :)
What I was really more concerned about what all of that "piston wash" stuff....where the fuel doesn't burn all the way and ends up down in the crank case. I thought THAT was the main reason they don't want you just sitting there at idle. |
[quote author=Hoss link=board=20;threadid=18143;start=0#msg169992 date=1060359488]
What I was really more concerned about what all of that "piston wash" stuff....where the fuel doesn't burn all the way and ends up down in the crank case. I thought THAT was the main reason they don't want you just sitting there at idle.[/quote]They call that wetstacking. |
