How to grease the front driveshaft
Old Nov 17, 2007 | 12:17 PM
plessm's Avatar
I've done lots of reading here, was able to find the small spot to inject grease. I bought a set of grease needles from Napa, which look about the diameter of a standard number 2 pencil lead.
I could not get the needle to go in at all. It seems like the hole in the grease area is very small. I had a air needle for pumping up basketballs and stuff. Tried to put it in the whole, still too big.
What needle are you guys using? Anyone have a part number that works for sure, and where you picked one up? I've got 8500 miles on my truck now and need to grease that joint.
Thanks.
Old Nov 17, 2007 | 03:20 PM
AlK's Avatar
AlK
This is what I use:
Old Nov 17, 2007 | 03:55 PM
Danavilla's Avatar
That's what I found to work best also. I tried the type that mates up to the surface and forces the grease in but I got more outside than in so I changed up. It works fine.
Dan
Old Nov 18, 2007 | 05:21 AM
XLR8R's Avatar
Now, if we could only find the hole!
Old Nov 18, 2007 | 02:19 PM
Dynocon's Avatar
I purchased one from NAPA and had the same issue, I could not hold the nozzle, gun and pump it. I recruted my 6 year old to hold and pump the gun and I held the nozzle, worked great.
All you need is a 6 year old to help!!
Old Nov 18, 2007 | 04:12 PM
plessm's Avatar
Haha, I have a 6 year old too. Actually, I was trying to stick the needle in the hole when I didn't even have it connected to my grease gun, just to see if it fit. It did not fit, too fat. I'm going to grab my drill bit set and crawl under there, use the blunt end of the bits to figure out the right size to fit, then try to find a needle to match.
Old Nov 18, 2007 | 09:00 PM
AlK's Avatar
AlK
XLR8R,
This should help you find it
Old Nov 18, 2007 | 10:46 PM
XLR8R's Avatar
Thanks!
That's the best photo of it I've seen.... now I might actually git-r-dun!
Old Nov 19, 2007 | 02:58 PM
Mallard's Avatar
great photo - Thanks...
Old Nov 19, 2007 | 03:04 PM
BMH95's Avatar
Ah yes, I just did that today. I use a 6 inch needle style from Napa, but always get grease on the outside too. I figure I fill the space, and then the excess runs back out. I may try the hypo style in the future.
Old Nov 19, 2007 | 06:39 PM
gsbrockman's Avatar
Old Nov 19, 2007 | 06:47 PM
Gunrunner's Avatar
I use a grease needle from NAPA as well, but I also have a grease gun with a rigid steel pipe, about 6 in long instead of a rubber line. Works great!
Old Nov 20, 2007 | 10:06 AM
ThatGuy34's Avatar
how much grease do you put in?
Old Jan 6, 2008 | 12:38 PM
alaskaflyer's Avatar
Originally Posted by AlK
XLR8R,
Thanks to this picture I finally found it. Looks fun to get too also! Now to find the right needle.
Thanks again!
Gary
Old Jan 6, 2008 | 05:27 PM
XLR8R's Avatar
Still haven't gotten around to lubing that nipple!
