How do I check transfer case fluid?
Old Feb 11, 2014 | 07:07 AM
rjweiss's Avatar
I'm seeing some atf4 leaking on the garage floor its not the tranny so I'm thinking its the transfer case. I really can't pinpoint where the leak is so I'm thinking I should check the transfer case fluid level.
I'm guessing its just pulling a plug?, if I knew where to look:-\
Thanks
Ron
Old Feb 11, 2014 | 07:38 AM
Dr.Dizzle's Avatar
Here is a link that shows a photograph of the transfer case fill and drain plug locations. It will require a 10mm Allen socket bit /wrench in order to remove the drain and fill plugs. https://www.dieseltruckresource.com/...d-t267899.html
Old Feb 11, 2014 | 04:33 PM
sherod's Avatar
Caution on the plug.... It is a tapered plug. If you tighten it too much, it will seat flush with the case. If that happens, about 3 hours with a chisel will get it back out. Ask how I know......Snug is good!
Old Feb 11, 2014 | 05:04 PM
Busboy's Avatar
I have started using Teflon tape on the threads that way I don't have to tighten it too much to get them to seal, also makes it easier for removal.
Old Feb 11, 2014 | 05:26 PM
Dr.Dizzle's Avatar
I find it a best practice to use a torque wrench and tighten items to the recommended torque specifications.
Old Feb 11, 2014 | 07:23 PM
rockcrawler304's Avatar
I know you're not draining it but just a bit of advise for anybody else reading this thread. ALWAYS make sure you can get the fill plug out BEFORE you drain the oil.
Old Feb 12, 2014 | 11:14 AM
rjweiss's Avatar
OP back, thanks for the advice especially about making sure you can get the fill plug out!
Thanks
ron
Old Feb 15, 2014 | 12:37 AM
duffer26's Avatar
look between the transfer case and trans joint that was where i was leaking not a big job to drop the case and replace the two seals there
KC
Oct 24, 2003 06:13 AM
Commatoze
16
Sep 23, 2003 11:15 PM
Mark Thomas
Jul 17, 2003 09:56 PM
KC
Jun 23, 2003 07:28 PM
