Transfer case fluid change, help... pic included
Old Apr 11, 2010 | 04:42 PM
HorseHauler's Avatar
Hi everyone, I am wanting to get my transfer case fluid changed out and am wanting a little help. I have not done this before but i know apparently its very simple. my question is, in the pic below, do I unscrew #2 (drain plug???) and let it all drain out and then unscrew & refill in the #1 plug (refill plug???). Is it that easy? I believe you use just over 2 quarts? I already have some mopar atf+4 ready to be used. Thanks everyone in advance...
Thanks,
Eric
Old Apr 11, 2010 | 04:48 PM
Also, Do i basically just refill the fluid up to the bottom of the fill hole? pretty much like the differentials?
Old Apr 11, 2010 | 04:52 PM
madhat's Avatar
Administrator/Jarhead
Yep.Remove both, drain, replace bottom, fill to bottom of top port. ATF 4. Tighten bolts to 30-40 Ft-lbs.
Old Apr 11, 2010 | 04:54 PM
sweet. thank ya!
Old Apr 11, 2010 | 07:26 PM
1985cucv's Avatar
make sure you have the allen in all the way as to not strip the plug out
Old Apr 11, 2010 | 07:39 PM
HL649's Avatar
It's also a good idea to take the fill plug out 1st just in case it is stuck. Would suck to drain it and then be able to fill it again.
Old Apr 11, 2010 | 08:22 PM
Thanks for all the help guys. Today was pretty good, got my fuel filter done, engine, rear end and transfer case. Transfer case was way easy. Thanks again!
good point HL649 lol that would suck!
Old Apr 12, 2010 | 01:47 AM
Jeff in TD's Avatar
One note the rear end. Later trucks have an oil level line stamped into the cover. You could miss it if you didn't know it was there. Fill line is a fair bit below the bottom of the plug.
Old Apr 12, 2010 | 05:08 AM
tlloyd's Avatar
How do you know when you have reached this line when filling?????
Old Apr 12, 2010 | 05:53 AM
ib516's Avatar
RE: Rear Diff -- Stick your pinky finger in the fill hole. If you can touch oil (by bending your finger downward to "reach it"), it's full enough.
Old Apr 12, 2010 | 06:14 AM
05HDRAM's Avatar
On the rear, just fill it till it starts to run out. Despite what some people have posted, it will cause no harm. I have over 40k on my rear will no issues.
Good advice on pulling the fill plug first on the t-case.
Old Apr 13, 2010 | 07:25 AM
kry226's Avatar
The manuals state to fill the rear to 1/4" below the hole, plus or minus 1/4". So, in reality, it's a wash. Anything from 1/2" below the hole to filling until it runs out is A-OK and within spec.
Old Apr 13, 2010 | 08:34 AM
Shorts's Avatar
Good topic! My tcase is next. What size allen is needed?
I did the rear diff on Sunday. I used 3.8L of Mobil 1. The reusable gasket makes the job super easy.
Old Apr 13, 2010 | 09:35 AM
Dr.Dizzle's Avatar
You will need a 10mm Allen socket bit /wrench in order to remove the drain and fill plugs.
Old Apr 13, 2010 | 09:37 AM
Shorts's Avatar
Thumbs up
Thank you. I have a 10mm in there. I was hoping I wouln't have to go buy one.
