How common would you say injector problems are?
Old Jun 26, 2011 | 04:07 PM
Roperteacher's Avatar
Just taking kind of an informal survey. How common are injector problems on these 3rd gen trucks? More specifically the 5.9's from 2006 and newer? I did a search on here and had over 400+ threads on injector related problems in the 3rd gen Engine forum alone. A buddy of mine says its extremely rare. I tend to disagree! Thanks!
Old Jun 26, 2011 | 04:11 PM
Grey Wolf's Avatar
Considering the 3rd has to fire more times per event that the older 12's & 24's. I would say time is against them, not to mention the increased pressures involved. I would have to agree with you..
Old Jun 26, 2011 | 06:00 PM
Blueboy's Avatar
It is a major problem with 3rd gens.
We have body,s and tips cracking
from to much pressure.
Old Jun 26, 2011 | 06:05 PM
Roadmedic's Avatar
Hard to say.
I had 406,000 on the first set.
I have 200,000 on this set. Still working fine.
I run some gray diesel from power service every once in a while. Rarely use additive even in the winter unless below minus 10 F.
Old Jun 26, 2011 | 06:25 PM
I had one replaced on my 2007 at 19,000 miles. Typical white smoke puff and rough idle once in a while. Now I have fuel in my oil at 100,000 miles so truck goes in to have them all pulled and tested. From what I have read its pretty regular occurance.
Old Jun 27, 2011 | 04:01 PM
jamesbfishin's Avatar
Had all 6 replaced with around 25000 miles, and then one replaced at 65000, have 85000 miles now and the traits of injector issues are coming back again. Doesnt seem to make a difference if I run additives or not, fuel filter is drained (never had any water in it at all) on reg intervals and changed according to owners manual recs.
Old Jun 27, 2011 | 04:57 PM
steelblitzkrieg's Avatar
DTR Detective
2, about 1000 miles apart back around 42k. I think they misdiagnosed which one was the culprit. Cost me 4 oil changes, they only comped 1.
I had just changed the oil about a week prior, they covered replacing the oil, I then changed the oil after 500 miles again to be safe. At about 1000 miles after the first injector was replaced I noticed fuel in the oil again, they wouldn't cover the oil this time and I had to change after another 500 miles to be safe again.
Thankfully I had 14 free oil changes as part of the purchase agreement, but that means I wasted 4 free oil changes.
I'm currently at 62k and he'll turn 5 on 07/05/11. Guess I'll be learnin' how to do them myself. I ain't payin' the dealer $1200.00...
Old Jun 27, 2011 | 06:50 PM
isb07's Avatar
53k no troubles at all never missed a beat. i have a 2 mikron filter setup and i change my filters every 5k
Old Jun 27, 2011 | 10:16 PM
DmaxEter's Avatar
171,000 and never a single problem. No injector cleaners or anything. Just been driven its whole life is all.
Old Jun 27, 2011 | 11:48 PM
I have had the 2 micron filter and Baldwin 5 micron on since practically new. Both changed every 5,000 on the dot! I guess some are just lucky and others not so much. LOL
Old Jun 28, 2011 | 12:03 AM
bigwheels94's Avatar
78K here with the stockers. I have a 2 mic set up, & change them @ 6K miles. Run TNT on SW9 for most of it too.
Old Jun 28, 2011 | 11:35 AM
dieselfreak21's Avatar
If you have proper filtration and water seperation and/or a good fresh fuel source they can last a while but by design they are prone to failure. They have gotten better over the years though.
Old Jun 28, 2011 | 12:45 PM
ssandlin's Avatar
I'm at 111K miles and no issues yet.....
Old Jun 28, 2011 | 01:30 PM
baytownbrown's Avatar
Lost 2 so far on my 2007, first one went at 53K and the second one died around 58K.
My old 01 power stroker which I handed down to my son has about 250K on the original sticks and still rolling.. go figure. You wouldnt believe how much crap I have to hear about it too!
Old Jun 28, 2011 | 02:49 PM
Foxborough's Avatar
92k miles on my truck, all stock. It's a daily driver till temperatures get above 40*F then I take the bike.
I did use some power service once I kept thinking about the stuff being snake oil and never used it again. So far so good.
