Horn problem
Old Jun 13, 2004 | 07:12 PM
Casey Balvert's Avatar
Horn problem
My buddies brand new 2004 has a horn problems. It starts blowing for no reason. Sometime for a few minutes, sometimes longer. He has disarmed his alarm, pushed his panic button but to no avail. The only way to stop it is to pull the fuse. The dealer said his cluster showed some error codes but replacing the cluster did not fix the problem. Now they are guessing at the problem. Anyone has a similar problem and found the solution for this. This is driving the poor guy nuts.
Casey
Old Jun 13, 2004 | 07:46 PM
BASSMAXX's Avatar
Sometimes it's best to start with the simplest solution. Have they checked for a bad horn relay?
Old Jun 13, 2004 | 08:20 PM
spots's Avatar
Or a defective horn pad?
Old Jun 14, 2004 | 01:11 AM
Turbo Deeezle's Avatar
Talking And I thought I was the only poor sob.
Mine did the same.......... I disconnected the horns and then found out of a friends doing the same thing. I plugged them back in after a few weeks and have had no problemo since.
Old Jun 14, 2004 | 04:31 AM
Looks like I screwed up putting this posting in the Drive Train section. Moderator can you move this to the appropriate section? Sorry.
bradmar08
Sep 24, 2010 06:00 PM
saltydog
Sep 3, 2009 10:55 AM
crobtex
Jan 21, 2009 04:52 PM
leftyrizzo
Jul 3, 2007 12:16 PM
