"hopping"
Old May 12, 2006 | 04:56 PM
herb's Avatar
"hopping"
my 6 speed is getting a hopping or jumping when i am backing up with a load.
Is this the beginning of a clutch failure? All seems well in forward gears
Old May 12, 2006 | 05:02 PM
TonyB's Avatar
Is it hopping when the clutch is partially engaged? Just reverse? It may be clutch chatter....Sorry not to be so much help. Others with more experience will chime in, I'm sure!
Old May 12, 2006 | 05:06 PM
herb's Avatar
yes, i am "feeding" the clutch pedal when backing up a 46' gooseneck trailer
Old May 12, 2006 | 06:01 PM
d0dg301's Avatar
Try putting it in 4 low and you won't have any problems.
Old May 12, 2006 | 07:32 PM
herb's Avatar
thamks, i will give it a try
Old May 12, 2006 | 09:12 PM
John H's Avatar
I have the same problem, but no 4 low. Any more ideas?
John
Old May 12, 2006 | 09:17 PM
abc4yew's Avatar
I get it going forward with the power up towing very heavy when the weight is on the trailer and light on the truck at intersections that are on an uphill grade and I know it is spring wrap.
Old May 12, 2006 | 11:49 PM
dodgezilla04's Avatar
may be driveshaft alignment. it is pretty long, and has a rubber mounted carrier bearing, and under the torque we put out, it may deflect.
Old May 12, 2006 | 11:54 PM
gerry's Avatar
Don't know about these trucks but in a large truck if you try and slip the clutch while backing it will hop and bounce....
You just put it in reverse and let it idle back...
Old May 13, 2006 | 08:42 AM
herb's Avatar
it moves to fast at idle to back and control trailer
Old May 13, 2006 | 11:32 AM
d0dg301's Avatar
Not sure, but I beleive reverse gear ratio is about the same ratio as what second gear is going foward.
Old May 13, 2006 | 11:54 AM
G1625S's Avatar
How are your motor/tranny mounts? When they get soft, they can twist pretty bad under load. Mine does it and I know my mounts are shot
Old May 14, 2006 | 10:49 PM
westcoaster's Avatar
Careful with backing in 4lo and dry pavement. You can wind your drivetrain up pretty fast. It will happen even faster if you have a heavy load on.
olbetsy98_12V
Dec 18, 2006 11:31 AM
olbetsy98_12V
Dec 17, 2006 11:05 PM
mainehunter
Aug 7, 2006 07:36 PM
Xplorer
Sep 19, 2003 08:42 AM
