Holset Turbo Question
I was curious if buying a reman holset turbo from the dealer was safe to do. The reason I ask this is because of the injector problems that so many have had when purchasing injectors at the dodge dealers. I just want to make sure before buying. Thanks!
Yeah, the turbo is a lot simpler than the injectors. Definitely don't hear about problems with them like you do with injectors.
That being said, a reman turbo at the dealer is going to cost you an arm and a leg, might want to consider going aftermarket or if you want to stay stock the Cummins dealer should be able to give you a much better deal.
kyle_truck_pull
Jan 12, 2010 03:53 PM
toyota31
Dec 22, 2006 11:55 PM
Cummins600
Mar 30, 2004 01:21 PM
