Hissing Noise
Old Sep 14, 2004 | 07:39 PM
tjr76's Avatar
Question Hissing Noise
I have a question about my 04.5 truck. At idle there is a hissing noise like an air or vacuum leak. I traced the noise to a black part on the back of the fuel filter canister. This part has a hose coming out of the bottom of it going to the fuel tank. If I kink the line while the engine is idling the hiss noise goes away. Is this normal or should I take the truck in to the dealer? Thanks
Old Sep 16, 2004 | 11:41 PM
tjr76's Avatar
Anyone?
Old Sep 16, 2004 | 11:53 PM
gsdog1's Avatar
I would be taking it in. This is my third CTD and never had anything like that taking place.
Matt
Old Sep 17, 2004 | 08:29 AM
Gwoody's Avatar
I think you're hearing the lift pump that supplies fuel to the CP3, it's normal.
Old Sep 17, 2004 | 09:25 AM
tobyw's Avatar
I've had the same noise from the same place since day 1 on my '03. Near as I can tell, it's not an issue? However, if you take it in and they find something, please let me know!!
Old Sep 17, 2004 | 12:32 PM
gsdog1's Avatar
Hhhmm, maybe I need to get my hearing checked! I will see if I can hear this later when I start the truck, paying more attention for it, but it seems odd.
Matt
Old Sep 18, 2004 | 11:17 PM
lightening ram's Avatar
the noise is a electric transfer pump, more like a buzzing noise possibly, no more mechanical lift pumps.
Old Sep 21, 2004 | 05:08 PM
tjr76's Avatar
gsdog1, did you hear anything on your truck?
Old Sep 21, 2004 | 06:38 PM
gsdog1's Avatar
Nothing like this. Unfortunately I am having an issue with relay chatter when I turn the key to the on position. When I start the truck, I have pinging going on. May be a trip to the dealer to look at injectors for me.
Otherwise, the only thing that I am hearing is the lift pump going through the prestart exercise. That all sounds normal to me, at least based upon what I got used to with my other two CTD's The sound is mechnical, and could be likened to a hissing noise I suppose.
Sorry, not much help I guess...
Matt
black03
Oct 31, 2008 02:38 AM
CDoskocil9
27
Jan 17, 2007 04:34 PM
Chinookce
Nov 1, 2005 06:19 PM
yorkpaddy1
Jan 24, 2004 08:05 PM
Hummin Cummins
14
May 24, 2003 01:20 AM
