High Idle on my 05 6spd kicked in!
Old Jan 11, 2005 | 12:12 PM
MonroeDiesel's Avatar
It was cold this morning, about 27 degrees, when I started my truck up. I walked inside to grab some coffee when I noticed my engine kick it up a notch. I checked the tach, yep 1100rpms. I thought my new 05 6spd did not have the high idle feature, only auto's. Am I wrong?
Old Jan 11, 2005 | 12:28 PM
rossn2's Avatar
The 6spds 03-05 have a high idle function when you get down below 30 degrees or so already programmed into the computer. If you walk away from the truck after starting, and let idle for about 2 min, the high idle kicks in. You should've noticed the grid heaters cycling too.
It's not quite the same thing on the automatics. On the automatics you can push the Cruise COntrol button to enable high idle at any temp, where you can't do that on the 6spds.
Old Jan 11, 2005 | 03:43 PM
Bubba_CTD's Avatar
From: From Texas; Staioned in WA; Transplanted to AZ
Yea, they have it in there... you jsut can't manually turn it on like you can with the auto's.
Old Jan 11, 2005 | 09:58 PM
BEHRMAN's Avatar
Yeh, my high idle works too.....but I can't tell it anything gets warm any faster. EGT's are only 50 degrees higher at 1000 RPM high idle.
bigd450
Dec 4, 2007 03:06 PM
jmccart
Feb 20, 2007 09:15 PM
lowboy18011
Mar 6, 2006 01:15 AM
westport
Nov 24, 2005 01:43 AM
norsk
Jul 19, 2005 08:26 PM
