Hestitation and white smoke
Old Apr 7, 2025 | 09:06 PM
BigstarATX's Avatar
Hey y’all. I was driving my 07 5.9 today and going up a small incline. I felt a sudden dip in power and then noticed white smoke coming out of my exhaust. I THINK I could hear like a whistle when I stepped on the gas a couple time. I pulled over and got out of the truck with it running and there was a puff puff of white smoke coming from the exhaust. I turned off the truck and looked in the engine bay and underneath…. nothing noteworthy. I started the truck and started driving. Accelerated hard a few times and saw the usual light black smoke I normally see under acceleration. I drove a couple hours home and didn’t notice anything unusual. Any ideas on what might have happened?
Old Apr 8, 2025 | 08:38 PM
BigstarATX's Avatar
50 views and nothing??
Old Apr 9, 2025 | 07:30 AM
Maybe air getting in the fuel system, or a strain on the fuel delivery system.
The fact that it "reset" itself after turning the truck of is interesting. It maybe a restriction in the fuel system. Think gunk at the bottom of the tank clogging the pick up filter. Once the suction on the filter stopped the gunk fell to the bottom of the tank...Maybe?
I would check the fuel filter and the fuel line connections from the pump to the tank.
Also check that the lift pump is working well and making enough fuel pressure for the injection pump.
Old Apr 10, 2025 | 03:20 AM
EmoryBest's Avatar
Glad it cleared up! Might’ve been minor just keep monitoring things.
Spoiler
Old Apr 10, 2025 | 07:27 AM
BigstarATX's Avatar
Thanks for the replies…. No sure what it was but I’m keeping an eye on it. Someone recommended running a quart of ATF through the fuel system. IS this a good idea of will it damage the system??
Old Apr 10, 2025 | 07:31 AM
What would the benefit be of running ATF?
I have heard of adding some two stroke oil to the fuel, to help with the "new" low sulfur diesel.
Old Apr 10, 2025 | 11:13 AM
FMB's Avatar
FMB
You might look at your post turbo to Intake air tube for split, holes, etc.
zethtays
Mar 9, 2010 07:26 PM
heminfiver
Apr 15, 2008 04:30 PM
Buffman88
Mar 29, 2007 01:21 PM
BuildingBoost
Mar 25, 2007 07:46 PM
zek405
Nov 17, 2005 06:46 PM
