Help - Truck shuts down - No codes
2004 2WD with 130K km.Truck shut down in parking lot right after starting. I had previously driven 20 km and truck was stopped for about 10 min. It had a long crank and then started. I drove about 5 min and the same thing happened again after stopping for a few min. Shortly after it happened while driving through town. Had it towed to a local diesel shop and they replaced the fuel pump in the fuel tank. Would not start after this and they said the ECM was faulty. ECM was sent away and tested. All good. Reinstalled the ECM and truck started but intermittently shuts down with no codes. Any help is appreciated? Thanks.
Anyone have any thoughts on this??
Trucks shuts down intermittently. Usually at idle or when shifting into gear although it did it once while driving around. Have changed the in tank lift pump, fuel filter, FCA and had the ECM sent away and checked. No CEL or codes. Any thoughts are appreciated.
I would check electrical stuff. Grounds, battery cables and connections........the box with the fuses in it could be causing it. Loose or corroded inside. Heck it could be maybe your key lock in the column? Just thinking out loud........
47
47
Thanks. I'm working my way through that at the moment.
