HELP!!! Torque converter want go in
Old Oct 12, 2006 | 08:26 PM
bigsilver's Avatar
Unhappy HELP!!! Torque converter want go in
It is 9:30 and still can't get my torque converter on my trans can anybody help me give me a suggestion on why it is so tight going in DUSTY if your out there this is Brian and I need help.
Old Oct 13, 2006 | 12:39 PM
dodgezilla04's Avatar
make sure that you are spinning the converter as you try to install it on the input shaft and engage the pump. keep turning left and right as you apply gentle for into the trans. you have 2 components you are trying to line up at once.
if that doesnt do it, sorry. good luck bud
Old Oct 13, 2006 | 01:59 PM
Spooler's Avatar
Yeap, spin left and right with gentle pressure pushing in. Sometimes they can be a pain in the rear.
Old Oct 13, 2006 | 08:15 PM
Checkmate's Avatar
Just make sure its allllll the way in before bolting trans in. I found out the hard way and have to pull my 95's trans back out and replace the pump after a total rebuild.
Old Oct 14, 2006 | 09:21 AM
ataboy9026's Avatar
I usually do a push in - pull out method as I am turning the converter. Only pulling out 1/16 to 1/8 inch as to not pull off splines of input shaft. I do this because the pump spinns very easily and the converter will spin the pump if it is being "pushed" and not ever engage. If you look the pump can only go in 2 ways, 180 degrees apart. But everybody has their own little "quirk" you just have to find your own way. Like others said though..... Do not try to put it in without being sure it has fell int place. You will have to pull it out about 1/16-3/16" in order to bolt to flexplate. If the converter touches the flexplate before the bellhousing touches the block it is not engaged!!!
Old Oct 15, 2006 | 08:24 PM
bigsilver's Avatar
Thanks guys but it was just a little minor over look on my part no big deal got it taken care of. Also Dusty at HTS is the man they have the best service and support.They get my 110% on tranny building .Let you know when I get all together and going and how she does at the track after I get some miles on the tranny.
lniemeyer2
Oct 24, 2012 12:11 PM
93dieselZak
Jun 16, 2011 06:10 PM
mainer
Jul 17, 2007 07:13 PM
PapaSmurf
Dec 19, 2003 02:14 PM
