Help with prob.
Old Nov 28, 2006 | 07:03 PM
cromulius's Avatar
Help with prob.
My truck started to sputter and loose some power. The check gauges light is on. As a green horn I would say fuel or ignition. Drained any water out of the filter housing and will drop at the dealer tommorow. Any ideas?
Old Nov 28, 2006 | 08:29 PM
Jeff in TD's Avatar
Where do you live? (How cold is it? Possible fuel jell?).
Old Nov 28, 2006 | 08:48 PM
cromulius's Avatar
Na, I'm in Texas.
Old Nov 28, 2006 | 08:58 PM
Jeff in TD's Avatar
Well, that's probably not it. Only knowing that you are new to diesels, have a new truck that's sputtering, and it just turned winter, that was my best guess.
Since it's a diesel, it doesn't really have an ignition system...
Anyhow, one of the neat things about having a new truck is the warranty. Let us know what they find.
Old Nov 29, 2006 | 06:15 PM
cromulius's Avatar
The dealer said it was a non active code and must have been a loose wire that fixed itself. I replied that things don't fix themselves. He said the tech cleared the code and test drove it with no problems. Before I got home the same problem happened. I called and said told you so. He said the diesel tech broke his thumb and went to the hospital so I should call back tommorow. Once again, good job dealer.
Old Nov 29, 2006 | 06:40 PM
Jeff in TD's Avatar
Did they tell you what the code was?
Old Nov 30, 2006 | 08:07 PM
cromulius's Avatar
The tech said he found a loose wire going into one of the injectors and recrimped it. The truck ran fine on the way home. We shall see.
jimbo486
Jan 28, 2009 10:41 PM
Tomtt
Aug 12, 2008 10:53 PM
falstaff
Oct 26, 2007 12:37 AM
bsj04
Jul 15, 2007 10:54 PM
travjrath
Apr 20, 2004 11:09 PM
