Help Please --New to the diesel world
Old Oct 8, 2008 | 08:20 AM
John Faughn's Avatar
Anytime the wait to start light comes on , I find that this helps with winter millage [ cold engine ] .
Other wise when it gets cold enough that it takes any longer for the engine to start .
The remote starter is in case you do not have access to plugging in , you could use both , but then you are paying for too much for energy , electric & fuel .
Old Oct 8, 2008 | 02:18 PM
Texasimport's Avatar
How much do you wish to pamper the truck. As soon as we start getting below 32 eavery night I go ahead and hook my truck up at night and use a timer. I have it set to start heating the block 2 hours before I get in. It seems more for me to have heat than to really help the truck. Once it gets below 0 then I add a couple more hours in the middle of the night as well. I think it then finally helps the truck get cranking.
Old Oct 8, 2008 | 02:42 PM
megacabdad's Avatar
Having it on a timer is a really good idea...
I plugged mine in for all night for about a month last winter...
...until I got my electric bill
I think if you time it so it heats up for an hour or two before you go to start it will be plenty...
Old Oct 8, 2008 | 05:39 PM
megacabdad's Avatar
I'm just gonna use a timer like the one's you would use for lamps and x-mas lights...
I don't see the need for anything fancy...
Old Oct 8, 2008 | 06:23 PM
NickBeek's Avatar
You need one that can handle the current draw of the heater. I don't remember but 15A seems to rattling around what's left of my brain.
Old Oct 8, 2008 | 06:29 PM
megacabdad's Avatar
Your brain still works fine...
Standard 115 volt receptacle's are rated for 15 amps though, and the block heater will draw far less than that...
Old Oct 8, 2008 | 08:49 PM
megacabdad's Avatar
for sure!
Yeah, I use about 10oz. of Power Service in the white bottle per fill-up during the winter months...
Old Oct 8, 2008 | 09:38 PM
RAMRODD's Avatar
Your truck will easily start in sub 0 temps without pulgging in, many plug in at warmer temps then that because it is easier on the engine and warms up faster.
Before I had a heated shop I would always start up the tractor and leave it plugged in while I let it warm up. Last remote starter I had, I would start up the truck in the morning with it pluged in and I never had any problums.
Old Oct 10, 2008 | 09:15 PM
mj007's Avatar
Uhhhh ..... I believe that the block heater is rated at 850 watts which will draw 7.39 amps at 115 volts IF I am remembering the 850 right
Old Oct 11, 2008 | 07:09 PM
ktm06's Avatar
I do the same thing plug it in for two hours with any timer you can find for a good deal.
Old Oct 11, 2008 | 07:14 PM
rich's Avatar
when i was geting hay up in new mexico and colorado i never plugged my trucks in and it would get down to 5 or 10 deg all the time
Old Oct 12, 2008 | 10:16 AM
apprentice's Avatar
yup timer plug 20$ set to 2 hours down to 0/32 below that 4hours. if it is -30 i leave it pluged in all the time.... i use remote start and leave it pluged in till i get in the truck no issues.
