Help? Loud Screeching when starting.
Old Sep 30, 2010 | 11:21 AM
HorseBack4x4Gal's Avatar
Exclamation Help? Loud Screeching when starting.
We have an 07 3500 5.9. Everyone once in a while you get a loud Screeching when you start it up. We have changed the starter three times. We checked all the pullys.... We changed the clutch. What can it be? It is making me crazy..lol
It only does this when starting then goes away.
Old Sep 30, 2010 | 01:13 PM
jhenson's Avatar
Not exactly sure about your problem but the screeching would lead me to believe it could be a belt problem. Keep us posted.
Old Sep 30, 2010 | 01:18 PM
gcssr's Avatar
could be compressor going south
Old Sep 30, 2010 | 01:31 PM
We have put a new belt. what compressor? we have put a new a/c compressor.
Old Sep 30, 2010 | 09:29 PM
pcgym's Avatar
I had the same type of issue... turned out to be the belt tension pulley.
Old Sep 30, 2010 | 10:03 PM
We changed that to..
Old Oct 1, 2010 | 01:37 AM
gcssr's Avatar
did you properly service the compressor with oil? it sounds as if the system has to much oil, and is trying to lock up. you may need to vacumn and start over.
Old Oct 1, 2010 | 02:34 AM
Jeff in TD's Avatar
Does it do it with the AC and defroster off?
I think as an experiment I'd briefly start it (cold) with the belt off.
That would at least verify that it is something driven off the belt.
Old Oct 1, 2010 | 03:04 AM
Dodgezilla's Avatar
Mine does this now that I installed my SRT10 hood. It only does it when it rains though and for me it's water dripping down on the belt. Screeches for about 1-2 seconds and then it's fine...
Old Oct 2, 2010 | 10:19 AM
Well I am hoping I found the problems. The starter gear on the south bend flywheel was half off. It does it with the a/c competely off.
It is an intermittent problem. It don't do it all the time. Makes no sence. WHY THE HECK would the Ring gear come off the flywheel? It isn't that old. I JB welded it on. Hope it stays.
Old Oct 2, 2010 | 10:30 AM
cbrahs's Avatar
jb weld isn't going to hold the ring gear onto the flywheel. they are either pressed onto the flywheel and or welded on. if it is a flywheel problem, contact Peter at southbend. He is a great guy.
Old Oct 2, 2010 | 10:34 AM
cbrahs's Avatar
you sure you are talkin the ring gear?
http://www.google.com/imgres?imgurl=...iw=996&bih=582
this is a pic of a ring gear
Old Oct 2, 2010 | 01:34 PM
That would be it. We starting getting the sound a while back then it got bad. I was able to get that ring on and off with a hammer.
QUOTE=cbrahs;2851025]you sure you are talkin the ring gear?
this is a pic of a ring gear[/QUOTE]
Old Oct 2, 2010 | 03:11 PM
cbrahs's Avatar
[/QUOTE]
then you need a new flywheel. the ring gear is spinning on the flywheel and there is your noise. contact Peter and let him know what is going on. jb weld is going to do nothing. the starter is going to see that and laugh. ring gears are heated up and pressed onto the flywheel and often tack welded.
Old Oct 2, 2010 | 04:41 PM
I hope so. It don't have many miles on it yet.
And the Hyr sytem already went.
then you need a new flywheel. the ring gear is spinning on the flywheel and there is your noise. contact Peter and let him know what is going on. jb weld is going to do nothing. the starter is going to see that and laugh. ring gears are heated up and pressed onto the flywheel and often tack welded.[/QUOTE]
ramseydiesel
Jan 5, 2010 06:31 PM
svh7878
Jan 14, 2009 11:50 AM
supercharger
Oct 28, 2008 05:41 PM
Wulfdiesel
Aug 30, 2007 07:49 PM
90dodge
Apr 6, 2006 07:23 PM
