help! eng.light!!! p0148 (hate lights)!!!!!!
Old Jan 23, 2009 | 09:35 PM
zking's Avatar
hey guys dont know what to do had my truck at the steelers 5 times they dont know what to do.2006 5.9 runs great,looks great,rides great,I love this truck. This fuel delivery code (stored not active) makes me crazy!!! they checked every thing they could guess I will just have to live with it.Any suggestions from you guys will be much apreciated.
Old Jan 23, 2009 | 09:44 PM
Totallyrad's Avatar
When my lift pump died I got two codes, P0148 was one of them. They explained it to me as the computer saw the difference between the readings on the rail. Whether that's correct or not, I can't say for sure. They should be able to clear it, I did with a Smarty.
Old Jan 23, 2009 | 09:54 PM
zking's Avatar
the light clears after 5 or 6 key cycles.Then after i drive it a day or two it comes back on.No missing,norunning rough nothing.
Old Jan 23, 2009 | 09:58 PM
Totallyrad's Avatar
You may have a bad pressure sensor, I really don't know.
Old Jan 23, 2009 | 10:03 PM
zking's Avatar
what happened when your lift pump died?
Old Jan 23, 2009 | 10:06 PM
Totallyrad's Avatar
Truck quit, fell flat on it's nose and would not restart.
Old Jan 23, 2009 | 10:09 PM
zking's Avatar
did it kill the high pressure pump?
Old Jan 23, 2009 | 10:16 PM
GOT BOOST?'s Avatar
0148 means that the ECM is calling for a certain rail p. and the actual measured rail p. isn't what the ECM is calling for. The actual rail p. may be too high or too low. Common problems that cause this are, in order of most common to least common in my experience
1. Lift pump 2. Fueling box faulty connections
3.FCA 4.Loose connector tube or improperly seated injector
4. Worn out rail pressure relief valve 5. Malfunctioning rail p. sensor
Unhook all fueling boxes and set programming back to stock, then monitor your fuel pressure to rule out the lift pump problem. Lots of times guys have larger injectors with aggressive programming that demands more than the lift pump can supply and you can set this code because the cp3 can get enough fuel when under heavy fueling demands. If you drive the truck like grandpa, do you still get the code? If not this may be the problem. Jay
Old Jan 23, 2009 | 10:19 PM
Totallyrad's Avatar
No, it was fine.
Old Jan 23, 2009 | 10:23 PM
zking's Avatar
no chips,no boxes stock funny enough the light only comes on when i drive it like grandpa when i drive it spirited it dont come on. I drove it tonight and today on the interstate hauling butt 75 to 85 for hours no light!
Old Jan 24, 2009 | 10:59 AM
Hintz's Avatar
Could be a rail sensor, mine did that for a while and my Rail Psi was doing wacky things, but this was after a injector swap. I went in and found an injector tube was torqued right. Retorqued it and fixed it, but since your stock Id check your rail sensor. Do you have gauges?
Old Jan 24, 2009 | 03:41 PM
zking's Avatar
no after market gauges
Old Jan 24, 2009 | 03:47 PM
zking's Avatar
drove the truck all day,no engine lights????mabie it is arail pressure sensor. im sorry for the bad typing i suck at computers.a budy of mine has an extra rail pressure sensor i think i will try that if the light comes back on
Old Jan 24, 2009 | 03:49 PM
zking's Avatar
thanks for the input
2Armor
15
Mar 1, 2010 03:37 PM
2500TurboDodge
Dec 12, 2009 08:45 AM
05CTDN8
Jan 23, 2007 09:35 PM
ptgarcia
27
Nov 18, 2006 09:00 PM
acker1
Jun 30, 2003 03:13 AM
