help !
Old Nov 29, 2011 | 06:12 PM
Eleblanc's Avatar
help !
I have developed a white smoke issue on My 03' . been to two shops and no answers ?
Old Nov 29, 2011 | 06:40 PM
Brian08Q35004x4's Avatar
From: This Nazi state of California 2nd home Gilbert AZ under God
Turbo seals failed and leaking engine oil into exhaust? Overheated oil rings? How does it run in general? Need more info, miles, mods, at excels ration or idle or both ect?
Old Nov 29, 2011 | 09:04 PM
leonesm's Avatar
White smoke is potentially a sign of injector failures. Have you noticed a decrease in fuel milage? Check your oil level and see if it has risen. Injector failures are common on these trucks, especially on the early 3rd gens.
I would think if the turbo seals were failing you would hear the turbo itself squealing. But checking the oil level will lead you in the correct direction.
Again, a little more info about the truck would help. When are you seeing the white smoke? How much smoke are we talking about? I would be cautious because if it is an injector causing your issue you have the potential to melt a piston depending on the severity of the problem. What did the other shops tell you?
Old Nov 30, 2011 | 07:29 PM
Eleblanc's Avatar
no signs
thanks for your replies. no signs of oil movement up or down, no turbo noise , no notable power or mileage loss ????????????
I am getting an occasional missing sound through the exhaust, very faint.....
no mods yet....
it start with lite haze at about 170degrees and gets a little heavier at temp.
Old Nov 30, 2011 | 08:21 PM
Eleblanc's Avatar
other trouble
change the fuel filter called a friend for info (he use to be a lab tech at a refinery). He believes the black crap in my filter is coke from bad fuel!
Old Nov 30, 2011 | 08:40 PM
Dr.Dizzle's Avatar
If this dark substance located on the filter is an oily sludge, it may be what is known as asphaltenes. There are products marketed to reduce the effects of this such as Fleetguards Fleet Tech Asphaltene Conditioner.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
