Heating up under WOT
Old Jun 28, 2007 | 12:51 PM
torkmnstr's Avatar
Have any of you guys experienced your water temp rising a little under wot, towing or on grades. I see that mine heats to a little over 200 degrees, but immediatly comes down when I let off. When normal driving it never moves. It has done this since I bought it. I have chalked it up to heat from the turbo which heats things up a little. Thanks for any imput!
Old Jun 28, 2007 | 01:04 PM
shortbed rv's Avatar
I have. I was towing about 13K in the Davis Mountains and if I could see the temp increase at WOT climbing. I just installed the Quad Commander so I tell more about what is going on.
Old Jun 28, 2007 | 01:16 PM
dodgezilla04's Avatar
well torkmnstr, you are running larger tires, pulling a grade, burning large amounts of fuel with quite high cylinder pressure(boost related) which increases cylinder temp, and something has to absorb all that heat. slightly over 200* is nothing. keep on going.
Old Jun 28, 2007 | 02:42 PM
soulezoo's Avatar
DTR 1st Sergeant
X2.
What you describe is exactly what I see too. Perfectly normal; no worries.
Old Jun 28, 2007 | 03:35 PM
Bark's Avatar
Normal for me!
Old Jun 28, 2007 | 03:46 PM
torkmnstr's Avatar
Yeah I knew it had to be turbo heat etc, just wanted to make sure you guys are seein the same thang!! Even so Dogezilla, it would do it with my stock tires as well. Thanks guys.
Old Jun 28, 2007 | 03:48 PM
Truckman0097's Avatar
Im running stock and I notice it pulling and on grades too every now and then. Never gets too high, just a hair over 200.
Old Jun 28, 2007 | 04:57 PM
the tires just add more load to the engine. that's all.
Old Jun 28, 2007 | 05:10 PM
neverenough's Avatar
I flushed the old coolant added zerex and a bottle of royal purple's purple ice and mine never gets over 200*.
Old Jun 28, 2007 | 06:15 PM
06megacabman's Avatar
Wheeew! I am glad to hear this. I have been experiencing this also and was starting to get concerned as now I have a 12K# toy hauler. Any issues pulling a grade and having it sit at that just over 200* mark?
Is there a point I should back off time period wise. Seems like I go from 190 to about ~210 pretty regularly when towing and hitting various grades.
Also, new to diesels. Is it ok to add redline water wetter or purple ice to the coolant in diesels? are they compatible?
Old Jun 28, 2007 | 08:46 PM
jrussell's Avatar
It's normal for a Cummins. They love it!
arcticcat1000
Mar 6, 2012 04:27 PM
jrussell
Feb 13, 2007 10:01 PM
Green04HO
Feb 8, 2006 04:12 AM
WhiteSport600
16
Dec 10, 2005 03:08 PM
2500TurboDodge
Aug 15, 2005 07:20 PM
