HE351Cw sensor
It controls the WG to control boost. They occasionally go bad and you are limited to 26 lbs of boost until its fixed or you clamp the boost reference hose.
One can take it apart and use it for boost reference to the WG with a boost elbow and get a resistor so the CEL goes off, or, remove it and replace with a bolt.
There is a rubber hose that runs from the WG controller to the WG actuator, when the controller is not plugge din you will only ge tlow 20's boost. Crimp that hose shut with a pair of vice grips or cut and plug the hose and you will have boost.
The CEL is in a truck that has the capability to read it, yours won't.
We are running HE351VE's on 2 gen 1 engines and can hit 40 psi easily on 12 cm settings. You should see 40 easily with enough fuel.
Ah, I missed your sig. You have this on a gen 1 engine in a Ford, correct?
if you apply 12 volts to the solenoid you get 32psi boost. you can unscrew the solenoid with a wrench or water pump pliers on the housing. it is epoxy filled and nearly non destructible. the best thing for you to do is either connect the solenoid up to the key to where it is hot when the key is on or tap the volute for a boost elbow and use a special plug from ats in place of the solenoid. if you go this route sell me the solenoid. i cut it open and convert it to mechanical
If he applies no voltage to it and puts in a boost elbow in the reference line he will have 40 psi and tunability.
The block off bolt is $40 plus and then one would have to tap the compressor for a boost source. Perfectly good source of boost with nothing to do but add a boost elbow.
Never could figure the reasoning on buying a $40 bolt AND tapping the compressor to get the same thing?
http://hoeslidiesel.com/store/page13.html
Not true, here is just one place that handles them. Take a look at his sig, the sensor is totally superfluous.
Carl48 If I remove and replace soleniod, You pay for shipping you can have it.
