Hard starting problem on 03 5.9
Old Apr 27, 2009 | 08:25 PM
91r/t's Avatar
Ok im a die hard second gen guy but my buddy just bought an 03 cummins with the auto and it has 120k on it. He says he is having starting issues and was wondering what it could be. He said he hears the lift pump run for a minute or more when turning the key on.....where is that located on the third gen. Whats the pressure suppose to be at? Anyone's help would be appreciated.
Old Apr 27, 2009 | 08:54 PM
Spooler's Avatar
Pull the fuel filter, drain the boil, and see if it will fill the filter bowl back up. If it does, then he probably has a bad injector not allowing enough rail pressure to build causing the hard start. Have a leakdown test done by someone, dealer can do it. If he does have this issue, pull them and send them to Don M at F1 diesel, have them rebuilt and upgraded to Flux 1's or higher depending on what he has done to the truck. New injectors from Cummins is like $600 a piece. Dealer is outragous at around $1200 a piece. Tips from Don are $1100 and change along with any where from $100 to $200 a piece (depending on what is wrong with them) to get them rebuilt. Call Midatlantic diesel or TRE diesel. They can give you a ball park better than I can.
Old Apr 27, 2009 | 09:25 PM
91r/t's Avatar
kk thanks will do tomorrow
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
cuz199824v2wd
17
Oct 5, 2006 09:47 AM
chadt
Feb 20, 2005 09:51 AM
