Greasing Wheel Unit Bearing
Old Jan 2, 2009 | 02:41 PM
HappyGA's Avatar
Has anyone else done this? I know it is sealed, but if you took the ABS sensor out could you pump the housing full of grease then?
I am trying to figure out a way to make these Unit Bearings last longer..
Thanks ahead of time for any info.
Old Jan 2, 2009 | 03:55 PM
johnh's Avatar
how long do you expect them to last? 200,000 miles?
Old Jan 2, 2009 | 06:35 PM
OOPS's Avatar
Unit bearings are a design flaw waiting to break, especially if you put different backspaced wheels and heaver tires on.
Old Jan 2, 2009 | 06:39 PM
Valv's Avatar
I replaced the ones from past 3 trucks at 190,000 miles, I cannot complain.
Old Jan 2, 2009 | 09:27 PM
billie's Avatar
I did mine when they were replaced, and once a year after if they look to be drying out. 1st set wore out around 50K miles. 80K now.
I pack sealed u-joints before I install them too. Factory gease always seem to be a bit lacking.
Cya
Old Jan 5, 2009 | 09:52 AM
HappyGA's Avatar
well, 200,000 would be nice since I am only getting about 35-40,000 out of mine..
I do have a slightly larger tire, but nothing overly large. 33-12.50-18
I ws just asking because if it works, then I can save $250 per bearing by spending 30 mins greasing the two of them when changing the oil..
Old Jan 5, 2009 | 01:25 PM
BMH95's Avatar
I've heard of people greasing them through the speed sensor hole.
I got a Napa lifetime warranty set, in case they do die. That way I don't have to pony up any more money. I'll still have to do the labor, but that won't be that big of a deal now that it's all slathered in anti-seize.
Old Jan 5, 2009 | 01:31 PM
TX_Diesel's Avatar
What kind of grease should be applied??
rob160
28
Sep 7, 2022 11:37 AM
GLHS
Apr 15, 2012 08:10 PM
DaNuGuy
Jun 4, 2005 05:10 AM
