Greasing the front UJ
I bought a greasing needle to grease the little indent in fornt of the transfer case and however hard I try I cannot get a good enough seal to get grease into the little indent.
Do I have the wrong size needle? The one I have has flat tip approx 1/16" in diameter a and a fairly sharp taper after the flat tip, approx 15-20 degrees.
I had a lot of trouble getting it the first time. Seems to need to be at the correct angle before it would work. Probably took me 30 minutes the first time that I did it. I am sure that it will get easier each time though as I get used to getting it in the correct angle.
I thought about gluing a small rubber "thimble" on the end of my shaft (ouch), so that when you push the shaft against the grease fitting, the rubber would seal it. I may try that next time.
cbrahs
May 18, 2007 11:20 PM
1stdodge
Jun 19, 2006 01:14 PM
MonroeDiesel
Dec 16, 2005 03:00 PM
tslewisz
Oct 24, 2005 07:01 AM
