Grease Fittings
I understand that there are several grease fittings on my 05 that are supposed to be hit pretty frequently. Does anybody know where they are? How often should they be hit? What type of grease should be used?
I guess it's not really a big deal, but I like to have all of my bases covered.
Thanks much,
Walt_Mink
Thanks much,
Walt_Mink
you got a fitting at each tie rod end [so 2] and if you are a 4x4, you might have one on the front driveshaft slip section and the fitting is in the end behind the u-joint [mine does not have this]
i hit mine with grease every oil change [so 2x per year] and this fall, i might drop my front shaft to grease the slip on it
Walt_Mink
I just changed the oil and greased the tie rods but I am still not sure where to grease the front drive shaft. Is there a grease zerk on it? I looked and could not see it, but there is a sicker by the radiator reminding me to grease it.
Please help!
Please help!
Please help!
Please help!
There is a grease zerk on the u joint (front u joint of the Front CV joint). It's painted over factory and very hard to see (had to scrap the paint off with a screw driver) This is not a normal grease zerk, more like a hole with a spring loaded ball in it, you do need the neddle attachment to grease this. hope this helps. I bought a small grease gun and needle (like hand held) to use for this. (if you buy it attach it permantly, it's hard to use a grease gun and the needle thing all in one, i can show you what I did with mine if you want.
I have an 03 and had both of my drive shafts off when I did my clutch. There was no grease fittings on any of my u-joints. I am familiar with the flush type fittings and have the needle attachment that I used on previous trucks. Dodge has gotten cheap with the newer u-joints. Mine are all sealed. Maybe they just started putting greasable ones on the 05's.
-Muzzy
-Muzzy
Bookshelf
Jun 2, 2006 11:17 AM
Rdstr2k
19
Apr 12, 2006 09:30 PM
