Got stuck in the sand; Don't want it to happen AGAIN!!
Old Nov 26, 2007 | 10:51 AM
  #46
nriver's Avatar
OT, There is a new amsoil product out on the market, Amsphalt. It turns sand into asphalt in 20 min.
BOT
How about a long winch cable and staying on firm ground to pull someone out.
Old Nov 26, 2007 | 11:04 AM
  #47
CrazyFloyd's Avatar
So when is Amsoil coming out with their own truck.
Old Nov 26, 2007 | 11:26 AM
  #48
CallmeD's Avatar
12 frt 8.5 rear good to go
Old Nov 26, 2007 | 11:32 AM
  #49
CrazyFloyd's Avatar
I will need a little more description because that is kind of greek to me.
Old Nov 26, 2007 | 11:34 AM
  #50
CallmeD's Avatar
I run 12psi up front and 8.5psi in the rear tires. E rated so the side wall is a little stiffer.
That gives me a nice wide foot print with 35x12.5x18. I can crawl up alot of the sand hills around here.
Old Nov 26, 2007 | 11:38 AM
  #51
CrazyFloyd's Avatar
Now I feel stupid. But I am definitely going to install some type of locking system in my differentials and also air down the tires.
Old Nov 26, 2007 | 11:48 AM
  #52
CallmeD's Avatar
give it a try with just air. Lockers aren't needed until you start liftin tires.
Old Nov 26, 2007 | 03:26 PM
  #53
falstaff's Avatar
LMAO at all the Amsoil jokes "synthetic air" LOL Amsoil reps do seem a little cult member-ike I gotta admit..
I got stuck on Pismo beach this year- pulling a 26' toyhauler loaded- 136 gallons water, 36 gallons gas, 4 dirtbikes and a quad etcetc easily 10-11kgross. I did air down the truck tires to12-14 PSI. I got all the way to mile marker 6 on the wet beach, did fine on the wet sand and then I went make a mad dash up into the dunes- (I didnt want to camp near the sardine packed maniacs) I made it 3-400 yards up hill, turned left to put my door/awning side opposite the ocean and that was it, she sank like a stone. Told my boys "this is where we're camping!" When ready to leave, someone asked me "didja air down the trailer tires??" Nope. After airing down trailer tires and a little digging, the Dodge backed right up and mosied on down the dunes like I was on Amsoil Asphalt! I still dont understand why airing down the trailer tires helps, but it does. Make sure you use a gauge, airing down to 30 PSI from 80 on load range E tires wont help at all- you have to down till the side walls flare out, typically under 15 PSI does the trick.
Old Dec 6, 2007 | 11:45 AM
  #54
rockindhk's Avatar
lowrange 1st gear low air pressure put it in gear open the door walk away and have a cool one it will get its self out!!! Gotta love a dodge
withalligators
Oct 8, 2014 10:22 PM
Baja
Jan 29, 2008 08:17 PM
Hammer
Oct 2, 2007 04:39 PM
Dave65
Dec 21, 2004 08:32 AM
