gears
Old Feb 1, 2004 | 01:41 AM
DesertDancer's Avatar
gears
much difference in running 410 gears as opossed to 373 as far as fuel mpg ???
Old Feb 1, 2004 | 04:42 AM
handymantim's Avatar
There are quite a few threads on "gears" and "mileage". If you do a search, you'll get a lot of info.
How will you be using your truck mainly? Unloaded? Loaded/towing? City? Highway?
Old Feb 1, 2004 | 07:22 AM
Casey Balvert's Avatar
As long as you don't have a lead foot there is little difference. Fuel consumption seems to increase above 2300 rpm on the gen 3s so with a 4.10 that represents a lower speed. Happy with mine but then I don't drive like a maniac either.
Casey
Old Feb 3, 2004 | 01:16 AM
Thanks guys for your input. Living out here I do mainly freeway driving which means a minimum speed of 70 or else you get run over, so being as how my pockets ain't all that deep nowdays, think I'll opt for the 373's.
Old Feb 3, 2004 | 08:02 AM
dodgedude361's Avatar
not sure what your gonna pull, but the 373`s are good for a lot of weight. the guys who do a lot of pulling, or pull heavy usually opt for the 4.10`s. i pull 6000 lbs, like its not there with the 373`s
Old Feb 3, 2004 | 12:09 PM
Jeff in TD's Avatar
According to Dodge, if I had the 4.10, my trailer tow rating would be 15,650 instead of 13,630. I really can't see towing anything that big, but will occasionally run on freeways with a 75 limit, so for me the choice was easy.
Old Feb 3, 2004 | 11:33 PM
Matt400's Avatar
3.73's all the way for that kind of driving, you might want to even run a little taller tire so she don't spin so tight.
BigJohnston
20
Jul 14, 2019 10:58 AM
Roarinbear
Dec 27, 2009 09:44 PM
93beater
Feb 28, 2007 09:28 AM
Turbodude
Jan 4, 2006 09:13 PM
walexa
30
Apr 8, 2005 10:26 AM
