Gear Shift Noise
Old Jun 9, 2004 | 07:15 AM
appydriver's Avatar
Question Gear Shift Noise
I have soft but noticable gear shifter noise in fifth gear. Mainly when the truck is ran for the first few miles. It is still there after but not very noticable. The dealer tech said it could be the syncronicers. Anyone else have the same noise.
Old Jun 13, 2004 | 12:43 AM
codystroh's Avatar
My truck does that as well and I only have 4400 km on it. It only does it when cold and goes away quickly, but when warm doesn't like to go into reverse.
Old Jun 13, 2004 | 06:23 AM
spots's Avatar
I have a whine in 4th. Has been there since new. Also had the clutch chatter but it has gone also.
Old Jun 13, 2004 | 07:09 PM
Casey Balvert's Avatar
Along with a rear axle whine my transmission whined in most of the gears as well with 4th being the loudest. Darned if it didn't disappear when they changed the ring and pinion in the rear end. The sound was telegraphing right up the drive line to the transmission. Quiet as a mouse now and I hope it stays that way.
Casey
Old Jun 13, 2004 | 08:23 PM
spots's Avatar
Mine is quiet in all other gears. My diff assy was replaced at 500 miles.
Old Jun 16, 2004 | 07:13 AM
Mr. Jimmy's Avatar
I also have the whine in 4th gear, but didn't go away after R&P replaced. I had the service manager document it the last time it was in the shop for 70 mph vibe, just for future reference.
Old Jun 16, 2004 | 08:32 AM
FiverBob's Avatar
Re: Gear Shift Noise
Can you define "gear shifter noise?" Is it a noise when shifting, or a noise when running in fifth?
Casey, did you have anything other than whine in yours?
Old Jun 16, 2004 | 03:44 PM
RockRover's Avatar
I’ve got an issue with a noise happening when I release the clutch, while stationary, after I put a little load on the trans…I noticed this at the local drive-thru the other day when I had moved forward, slipped her out of gear, THEN released the clutch…The noise is auditable with an associated thunking sound. My feeling is that it is simply the through-out bearing letting go from the fork (that is if this 5600 clutch works the same as an old NV clutch)…Or it has something to do with a dual-mass clutch or some such thing I don’t know anything about…Any collective ideas on this one?
Also, anyone else have any seepage issues around your bell-housings? I’m 99% sure I’ve got a rear-main seal leak…It drip’s once a week or so. Any ideas?
--D
Old Jun 17, 2004 | 07:11 AM
appydriver's Avatar
Shifter noise
The noise I'm talking about happens in fifth gear at between 40 to 50 mph. altouth it is still there at faster speeds only not as loud. I have had other 5 speeds that had bearings get routh and they sounded similar to this. After hearing thr r&p issue I'm not sure. Took it in for the noise but they say they don't hear it. Although they did document I had a issue at 13000 miles with trans noise.
MoparRiggan
29
Nov 9, 2008 12:02 AM
poogan
May 4, 2007 08:47 PM
CASMOKIN
Competition / Pulls / OffRoad
Dec 30, 2005 01:28 PM
appydriver
Jan 15, 2004 02:39 PM
