Gear Ratio w/ bigger tires
What up? I just went to 315's on my truck. I immediatly noticed the change in MPG (I expected it) but I had a guy tell me that I should change the gearing on it to help MPG's. I am looking for someone who has done this or knows something about it. Changing gears and getting the speedo adjusted? Also, am I right to think the overhead computer will be off on the MPG estimate? Looking for replies....Thanks
From: Used to be missoula, montana: Now in Sonoma County California
with a 6spd 315's and 3.73's is right on the money my mileage is actually up at higway speeds 1700-1800 rpm vs 2000 rpm before and the mileage has not changed in town. I miss the 3.54's and 315's on my old 12 valve but this common rail truck is defiantely a step up for me.
i will never install 4.10s ever again. ive had em before and they jsut didnt fit anything i was doing.
Also, the overhead reads less mileage then actual, lowering your #s. But they read high usually anyways, so sometimes you break even.
I had 3.55s, 6 speed and 315s on my 01. I thought the gearing was great for highway(2000 RPM = 80 MPH), especially since the speed limit in MT is 75 MPH on the highway and 70 MPH on two lane.
I don't see a need for 4.10s unless you tow real heavy all the time.
I plan on going to 315s on my 03 Auto.
315's will not be that hard on the truck to spend money for 4.10s unless you really want them. You will lower mpg in town but higher on the highway so it works out.
I'm happy with 315's and 3.73's on my '05. I don't pull that heavy over the road, tho, about 8000 lbs. A little HP adder from Quad more than makes up for any reduction in torque multiplication.
I had the speedo recalibrated.
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Inferno Ram
15
Jun 2, 2006 10:14 PM
Andrew k
May 11, 2005 10:17 PM
