Gear change
Gear change
I am wanting to change my 3.73 gears for 4.10 because of tire size change. Has anyone swapped out gears and had any problems or whining noise with aftermarket gears?
It's a lot of work and money for a very small change. As for the whining it is almost allways a result of poor installation. In order to be strong and live gearsets need to be setup carefully and it can take more time than a lot of people are willing to spend. That is not to say that all of the aftermarket gears out there are the same, it's just to warn you that a good set of gears set up by a bad technician are likely to be weak and noisy.
Good set-up is the key to any diff change. If the gears are making noise it means they were not set-up right. On my rockcrawler I perfer Richmonds or Yukon gears they seem to last the longest.
this is a diffrent question that most ask. BUT im lookin for a lil higher mileage or lower rpm i do what i need and drive 55 and im getting around 20 give or take. but i thought if SOMEONE made a shorter gear so i could get say maybe 23 or meh why not 25 yeppie for me. i put on about 400 a week for work. so it would be nice
Put 35's on a truck with 3.73 and you get about 3.30's...great for low rpm's empty...bad for pulling.
http://www.dirtroadmagazine.com/gears.htm
dodgebowhunter
Jun 29, 2009 08:59 AM
jmccart
13
May 27, 2009 09:45 PM
markm4
Jul 29, 2007 11:16 AM
doitl8r
Jun 4, 2004 11:14 AM
