Gages quit working
Old Mar 11, 2011 | 08:38 PM
budbon's Avatar
Gages quit working
The gages on my 2005 quit working - all but the fuel gage. At the same time the "check engine" light came on. Even my Quadzilla gages quit working. any suggestions?
Old Mar 11, 2011 | 08:44 PM
jhenson's Avatar
I'd try removing the Quad and set everything back to stock, then disconnect the battery cables for 20 mins or so to reset the puter. See if that helps...if not I'd start checking fuses.
Old Mar 11, 2011 | 08:49 PM
budbon's Avatar
Are you saying remove the Quadzilla Commander?
Old Mar 11, 2011 | 09:09 PM
jhenson's Avatar
Yep, just trying to isolate a likely problem. If you remove it as stated above and things work the Quad is the problem.
deezel
Mar 12, 2005 10:14 AM
j28s
May 26, 2004 03:02 PM
j28s
May 24, 2004 08:34 PM
Garz
Nov 17, 2002 02:02 PM
