G56 shifting
Old May 26, 2008 | 07:42 PM
  #31
D-Roc's Avatar
Originally Posted by doubledodge2003
i talked to the tech at royal purple, he told me to use thier synchromax, its for use in trannys that require atf+4
what i was told , still a lil unsure, ive used redline before and liked it, but see lots on here dont really get good results with amsoil. so still not sure what ill use
Says nothing here about ATF+4:
"Synchromax™ is recommended for manual transmissions that
specify an automatic transmission fluid or motor oil. It is also ideal for
4x4 transfer cases and / or 2-cycle motorcycle gear boxes.
Synchromax™ is formulated with Royal Purple’s synthetic, proprietary
Synerlec® additive technology, which offers improved shift
quality over a wide temperature range and reduced gear noise.
Synchromax™ is fully compatible with all types of friction materials
and offers excellent corrosion and oxidation protection without
affecting the soft metals commonly found in manual transmission
synchronizers."
But its your transmission, and of course the tech is going to tell you that...they want to sell their product.
Old May 26, 2008 | 07:44 PM
  #32
D-Roc's Avatar
Truthfully, I might give it a try though...doesn't matter to me, my warranty is up on the transmission anyways. And, who know? It may improve shift quality after all over transmission fluid. I've honestly never liked the idea of the red stuff in my manual...
Old May 26, 2008 | 09:08 PM
  #33
doubledodge2003's Avatar
synchronizers."
to a point i agree, but i had a 5 speed mustang and it called for atf fluid and i used royal purple and it was like a new transmission, super smooth and quiet.
i just dont wanna have a tranny problem and they are like well u didnt use mopar atf+4 so your warranty is shot. i know by law they are not supposed to void it but dodge is very funny when u have a warranty claim, but i know that if i use rp, amsoil or redline the tranny will smooth out
Old May 26, 2008 | 09:42 PM
  #34
D-Roc's Avatar
I hear ya, but I have no warranty so I may just try the RP.
Old May 26, 2008 | 09:50 PM
  #35
renopker's Avatar
you guys need to try a weighted shift **** for your shifting woes...altho the G56 does normally shift really nice for a big trans it could be improved some.
weighted shift ***** have been used on the sports car shifters for YEARS with great results...I figured if it helps that much on small gearboxes that it will work just the same on our BIG gearbox trannys...let me tell you it does.
weighted shift ****=shifts like butter
http://www.uintadieselperformance.co...ift_Knobs.html
the g56 already has a weighted shifter
Old May 26, 2008 | 09:53 PM
  #36
53 willys's Avatar
G56 does not have a weighted shift **** form the factory....it may have a heavy stick..but I feel that is for vibration not shifting ease...the weight needs to be up top..not down low by the shift tower
Old May 26, 2008 | 10:46 PM
  #37
HONKEYTRUCK12's Avatar
Love the g56. solid, positive shifts. A fluid change made mine a little smoother, just enough to put a bigger smile on my face. I could not ask for a better tranny in this application.
Old Jun 3, 2008 | 06:54 PM
  #38
cwgtex's Avatar
Question
53 ******, tell me more about your weighted shift *****. Do they screw directly onto the stick threads? How much higher are they than the factory **** once installed (how far does the stick go into them)?
stickk
Aug 20, 2009 11:02 AM
usmc5593
Jul 9, 2009 09:27 PM
xeon
Jan 24, 2007 10:36 PM
98 Ram 24V
Dec 24, 2005 10:19 AM
