Fuel transfer pump
Old Jun 4, 2009 | 11:52 AM
misplacedtxn's Avatar
Fuel transfer pump
My transfer pump crapped out on me on the interstate two months ago. Got it replaced. Since then, every fill up I can put 39-40 gal of fuel in the tank. I can't figure it out since it is a 35 gal tank. 8% of the tank's capacity is used for reserve which would be 2.8 gal. Before the change out I could only fill up around 34 gal. and that is w/ the needle on the "E" post. I am famboozled, but I am also blonde. Anyone else w/ this issue?
Old Jun 5, 2009 | 07:33 AM
A little help here. Anybody?
Old Jun 5, 2009 | 08:15 AM
trik396's Avatar
Sounds like you've got a mystery truck. No real explanation for you... maybe the fuel pump itself is off because I see no way to stuff that much fuel in your tank UNLESS when they replaced the pump they did the fuel tank vent mod at the same time...? I can get 37 gallons but I'm sure it'd go for more. I just don't run it down that low.
Old Jun 5, 2009 | 10:12 AM
I thought the same thing about the tank vent, but they didn't do anything w/ that. Oh well, I guess I can't complain about 700 mi per tank. I just don't want to be in a situation where I need my reserve and I am using it and not knowing it.
Old Jun 5, 2009 | 05:54 PM
rich's Avatar
the same thing on my truck since they replaced the pump in the tank. it will take more then 35 gallons when empty
Ahousat Diesel
22
Jan 12, 2014 12:05 PM
derceg
Dec 23, 2009 07:24 PM
csramsey640
Jul 6, 2006 04:44 PM
8mpg
May 22, 2006 01:35 PM
