Fuel Rail Pressure
Old Jan 21, 2006 | 05:23 PM
Underpsi's Avatar
Fuel Rail Pressure
Does anybody kn ow the stock specs for the fuel rail pressure on an 05? Someone told me that 22-23,000 is stock but today I took the chips off my dads 05 and it was completely stock. The only exception was the outlook monitor but it only monitors everything so I was giving her and I saw atleast 24,500 psi in the fuel rail just under 25,000psi. Should I be worried about this?
The truck did have an edge ez stacked with bdpp and it would get just under 27,000psi.
Old Jan 21, 2006 | 06:22 PM
J BODY's Avatar
There is no "spec", the ecm varies the "setpoint" depending on conditions and load. Trick is that you want your rail psi to mirror the setpoint. Personally I'm not too big a fan of any box that increases rail psi. The only failed pressure limiting valves I've seen have been with "bombed" trucks that increased the rail psi.
Old Jan 21, 2006 | 06:24 PM
Underpsi's Avatar
no boxes are on right nowit is 100% stock as far as fueling is concerned. I just thought that over 24,000psi seemed high for stock
Old Jan 21, 2006 | 07:39 PM
Superduty's Avatar
160 bar, 23,206 PSI, according to the 05 Shop manual. It isn't a spec that gets tested, but it is listed as a maximum.
Old Jan 21, 2006 | 11:39 PM
Underpsi's Avatar
think we should be concerned then if its going over the 23,206 psi?
Old Jan 22, 2006 | 12:07 AM
Superduty's Avatar
There was a poll in 3rd gen aftermarket showing that the injector failure rate was 4 or 6x higher on engines running boxes versus those that weren't. I suspect, but do not know for sure, that higher pressures were involved with running those boxes.
I would not increase the rail pressure on my engine under any circumstances.
Old Jan 22, 2006 | 08:12 AM
MikeyB's Avatar
Don M had pics of what happens to injectors that has been used with pressure boxes. The problem is bore erosion. The higher pressure slowly eats away at the metal. It's a slow process and the user wouldn't notice until the damage is done.
If you are running a pressure box keep it set to the lowest setting, or just don't run it at all.
MikeyB
Old Jan 22, 2006 | 12:01 PM
AK RAM's Avatar
I occasionally see a little variance in what the Outlook monitor reports….same settings with no changes. I really wouldn’t bet on it being 100% accurate, for what its worth.
Here is the thread by Don on rail pressure with pics: http://www.nwbombers.com/forum/index...opic=13895&hl=
Old Jan 22, 2006 | 12:07 PM
Superduty's Avatar
I'd be more worried about cracking injector bodies than orifice erosion.
The HP gains at WOT due to pressure are not that significant. The fuel delivered varies as the square root of pressure, so going from 23,000 PSI to 26,000 PSI yields:
sqrt(26,000)/sqrt(23,000) = 6%. On a 325HP engine, that is 20HP.
Old Jan 22, 2006 | 12:42 PM
Underpsi's Avatar
The truck is completly STOCK right now 100% STOCK fueling I simply want to know if you guys think that mid 24,000 psi is too high for a stock fuel rail pressure because that is what my dads 05 is getting right now with it 100% stock. I repeat NO FUELING BOXES OF ANY KIND IT IS 100% STOCK. Does 24,500 psi seem high for stock fuel rail pressure? If so could a regulator or something be messed up?
Old Jan 22, 2006 | 12:44 PM
Superduty's Avatar
I know you are stock. I'm getting PM'd by non stock people watching this thread, thus my comments.
Old Jan 22, 2006 | 12:47 PM
Underpsi's Avatar
Ok sorry about that I thought you just weren't getting my point that it was stock lol. I guess you don't have an answer to my question then?
Old Jan 22, 2006 | 12:49 PM
Superduty's Avatar
I have no answer.
Old Jan 22, 2006 | 01:37 PM
AK RAM's Avatar
That is the same pressure the 03/04s run according to the 03 manual, however, on the 04.5 and 05s, people that measure rail pressure have reported slightly higher pressures than that stock. Also, I remember reading that Don M recorded significantly higher rail pressures on stock 04.5/05s verses 03/04s when he started working on their injectors. Makes you wonder how much variance there is from truck to truck. If you search for some of Don M's old posts and read his ramblings on fuel system test results, he has shared some good info in the past.
While I'm quoting Don, he has also said that he didn't see any problems with injector bodies until he reached the 31,000/32,000 psi range if memory serves me right. Other problems with tips and seats turned up at lower pressures before the bodies had issues.
Old Jan 22, 2006 | 01:54 PM
Underpsi's Avatar
no way id ever let it get that high even with an edge ez and bdpp on extreme they didn't get close to that high
