Fuel pump on 03. Where? How many?
Old Jan 6, 2003 | 03:39 PM
FiverBob's Avatar
What smarter than me knows where and how many fuel pumps on the 03 CTD? In tank? In engine compartment? <br><br>CuriousBob
Old Jan 7, 2003 | 04:01 PM
FiverBob's Avatar
Re:Fuel pump on 03. Where? How many?
Coming back to the top. Surely someone knows where the fuel pump is on the CTD. Help me out. <br><br>Bob
Old Jan 7, 2003 | 04:23 PM
blownbanana's Avatar
I believe the &quot;fuel pump&quot; (Fuel Transfer Pump aka Lift Pump) is attached to the rear of the fuel filter/water seperator housing. If you mean the &quot;Fuel Injection Pump&quot;, it should be attached to the back of the timing gear cover at the left rear of the engine. HTH
Old Jan 7, 2003 | 09:48 PM
Casey Balvert's Avatar
The lift pump is attached to the fuel filter housing. No fuel pump in the fuel tank. Then there is the fuel pump or gear pump and finally the high pressure fuel injection pump. The last two are attached together to form one assembly.
Casey
Old Jan 7, 2003 | 10:21 PM
FiverBob's Avatar
You are both gentlemen and scholars. You gave me the answer I needed. Thanks so much. :P<br><br>GratefulBob
bobg333
14
Jan 13, 2008 09:33 PM
TXlilbro
Jan 12, 2008 05:32 PM
Txwelder
Sep 27, 2007 07:48 PM
Moose10
May 16, 2006 05:41 PM
joelmopar12
Jan 23, 2006 11:00 AM
