Fuel Pressure ???"s
Fuel Pressure ???"s
Need a little advice here. I went on a 600 mile trip for the holidays last week. 20 miles into the 600 mile trip, my Autometer Phantom ll guage fell from 10psi to 0. Truck ran great all throughout the whole trip. Not really sure if the lift pump went out or not because I had all the normal power. Truck felt fine. Had Smarty on Level 3 and hammered on her a few times up a couple of 5% grades and she ran right up them. Not sure if the CP3 can suck that much fuel, so I'm asking??? Did the sending unit just take a poop, or can the CP3 really suck that much fuel? Is it pretty common for the Autometer fuel sending unit to crap out? Any advice would be great. Thanks
Jason
Jason
the cp3 can pull fuel but not as much as the GM pumps. they are designed to pull fuel since the trucks don't have lift pumps. I would think that your sending unit took a dump if you were able to hammer it on 5% grades with smarty on 3. Like said above, drain the bowl and pull the cap, have the wife cycle the key and watch for fuel or pull the sender and make sure it is not plugged with gunk and cycle the key to flush the line
Tap a cheap gauge on the CP-3 or filter fitting to validate where the problem is. I have had that happen twice on my ISSPRO with the isolator and it has been low fluid every time.
Its not unusual for the pump to perform quite well in no load running and not flow enough under demand to keep up. The presure is the only way to know for sure and is easy to test.
Let's calculate how much fuel you use when WOT at 60 mph...
Lets say you get 6mpg at WOT going 60mph. That's a mile per minute, six miles to a gallon, so every minute you burn 1/6 of a gallon of fuel. 1/6 of a gallon is about 21 ounces.
So in a minute you will burn through 21 ounces of fuel at WOT. What do you think the volume of the fuel canister is? Lets say it's at least 21 ounces. So if the lift pump fills the fuel canister in less than one minute, you have excess fuel being supplied to the CP3.
These are not measured numbers of course. I bet the fuel filter canister is a quart, so if it fills half way in a minute you're probably good. I bet what you'll find though is a little trickle or nothing, or it fills the canister in 5 seconds.
Hopefully someone can fill in some details, but this is the thinking I'd use to see if the in tank pump is good.
If the pump has failed competely or is only running at partial capacity it will be noticeable but thats the exception to the rule.
The flow test is a single point snapshot in an open system, no other way to perform it reliably. It does not take into account pressure build up over a time period.
Its not unusual for an electric fuel pump to pass flow test at no load and fail test under pressure and time.
Consistent pressure measured at the CP3 inlet is the only positive way to gauge LP health.
Well my sending unit is right between the GDP MK-2 2 Micron and the CP3. Is there any chance that the filter could be plugged enough to show zero PSI? The filter has been on there for about 4 months now and the gauge went to zero right after I filled up from 4 gallons of fuel in tank to a full 35 gallons. I'll put a guage in the "T" and see what it reads. The wife took the truck to work so I can't do much for now. If the temperary gauge reads zero as well, I'll connect it to the filter housing and go from there.
Jason
Jason
8k miles on it. They told me this is pretty common with these paticular
units.
That really makes a guy want to buy another from them. Is it possible to buy another sending unit from Isspro or someone else that will actually LAST?? ThanksJason
What I do think is wierd is that if I manually set my high idel, it does not lope. If I leave the truck be and it enters high idel on its own, then it lopes. Kinda wierd
