Fuel Mileage
Fuel Mileage
Just curious, what kind of fuel mileage is everyone getting. I have an 07 Ram, club cab with 8 foot bed. I am also running with a canopy. I am getting an average (hand calculated) of 17MPG. When towing my 24" enclosed car trailer I'm getting 13 MPG average. Running a EZ.
I should of included that my truck id 4WD.
19.5-20.5 consistantly, hand calculated, filling tank until pump shuts off, then let the foam subside, then do that a bunch more times to get a few more gallons in.
If I stopped the first time the pump shut off I'd probably be at 21 MPG.
my 99 you cant do that.
99 is around 17-18
03 is around 19-20
i dont check MPG every time.
Order of importance on mpg:
- Truck specification
- Climate
- Terrain
- Truck Use
After that, as Shorts indicates, it's the average mpg that counts. Highs or lows are too easily manipulated. It is not a basis for comparison as -- in the end -- it comes down to the gallons purchased to cover the miles travelled (and that includes extended idle time where mpg is not zero, but negative).
How much am I spending for every mile?
Cents-per-mile is handy for predictive purposes. How much will it cost in fuel to travel X-miles?
So, the purchase price of fuel over an expected trip length is useful. If my fuel cost is Y-cents per mile then it's easy.
What's my mpg then, (as above) doesn't mean much. What's my fuel cost per mile . . now you're getting somewhere.
I can tell you my average is 22-mpg, but the useful number is that fuel costs me (while solo) 15-cpm.
If I make a run to San'tonio of 312-miles, then I'll spend right at $47. (312 X .15) at the present price of $4/gl.
- Compare the average mpg
- Look at differences of spec, climate, etc
- See where the fuel cost is the real clincher
If Shorts is averaging 15-mpg, then the cpm is 26-cpm. Highway will be a bit lower, and all city a bit higher than this. But it's still a good number to use to see what my out-of-pocket expense will be. That's what counts.
If I drive 12,000-miles annually, then at 15-mpg, or, 26-cpm on average, my fuel cost will be $3,900.
Etc.
- Climate
- Terrain
- Truck Use
Etc.
[QUOTE=Rednax;
.[/QUOTE]
Just to nitpick. If ones displacement is 0 (not moving) your denominator can be anything >0 and 0 is the result. Speed (MPH) is a scalar quantity, not a vector, and is understood to be an absolute value. So even if you coast backwards at idle your MPG will be positive because the numerator will always be positive.
.[/QUOTE]
