fuel line quick connect leaking
I was using someone elses thread. to try and find my answers. but i thought get more with my own. the quick connect on the back of the fuel filter canster. it is the supply line from the tank. is there an o-ring in it. or do have to replace the line. but insteed of that i will splice from the connecter the the metel line with rubber hose. not sure what is the way to go here.
If that fitting on a 2003 is the same as on a 2002 - a Dorman fitting- you can get the plastic inserts at NAPA or just about any auto parts store. Just unhook tfhe fitting, remove the plastic insert and replace it. I've had to replace a couple on mine. The one you are looking at is probably 3/8ths inch.
i'm going to tare in to it tomarrow. i hope it has an o ring. but if not i'm going to get rid of the quick fitting. and go with a push lock and rubber hose. this started after the dealer. was checking injectors and my lift pump. dont know what they did. but now it's up to me to fix.
well after looking around i could not find what i wanted. so i gave glacier diesel a call and now i'm all fix up. parts should be here end of the week. and no more leak. very help full people and patient since i know nothing about the fittings i needed.
Don't mean to hijack the thread, ok maybe I do, but I have a pretty hard dripping fuel leak that looks like it is coming from the front end of the fuel tank somewhere. Thought it might have been the connections on the top ofthe tank but when I took the bed off it wasnt' there. After more searching it is under the cab and looks like its along the frame rail where I can't get my hand into it. Anyone have any ideas.
i dont know about an 04 but i can see my fuel lines. when i get under the truck. if yours are like mine 06. right bought where the upper control arm bolts to the frame. they go from metel line to some nylon stuff. it could be leaking there.
The fuel line on my '03 was all plastic in a plastic sleeve. I have replaced mine when I inslalled the Fass 95. I did find that 3/8 fuel line will slip over the plastic line with a snug fit. If you decide to replace a section of the plastic line for a quick and not perminant fix place a short piece of 3/16 copper tube inside the plastic so as not to crush the plastic line under the clamp.
dieselfan
13
Mar 20, 2018 08:58 PM
robby t
Dec 16, 2013 09:22 PM
RHC
Oct 26, 2009 11:17 AM
chucktownsend5
Apr 3, 2005 07:53 AM
