Fuel Filter Replacement
Old Sep 18, 2011 | 09:00 PM
RamGazer's Avatar
10 Year Member
I found the fuel filter replacement in the DTR WiKi. What do you lube the o-ring with? I tried doing a search for fuel filter and I keep getting a blank page and when I go back a page it says I have to wait before I do another search.
Old Sep 18, 2011 | 09:12 PM
dezeldog's Avatar
I just use a little of the fuel that I've captured from draining the filter housing.
Jim
Old Sep 18, 2011 | 09:47 PM
06RAM2500's Avatar
Or clean motor oil.
Old Sep 19, 2011 | 07:04 AM
Sur5er's Avatar
Oil is good, Diesel not so good. The ULSD seems to lack the lubricity and can cause the O-ring to pinch/nick. I use a thin layer of Dow O-ring lubricant and have never had a problem with any application. BTW, not good for oxygen O-rings (compressed air OK), makes loud noises, launches O2 bottles without clearance, irritates co-workers and may spoil your employment record
Old Sep 19, 2011 | 07:26 AM
MikeyB's Avatar
I use silicone grease.
MikeyB
Old Sep 19, 2011 | 08:45 AM
dezeldog's Avatar
I've been going with the diesel fuel for over 600k and 2 trucks with no probs what so ever. Its hard to teach an old dog new tricks: cheers:
Jim
Old Sep 19, 2011 | 09:38 AM
RamGazer's Avatar
10 Year Member
I also forgot to ask, what is the dia. of the tubing to drain the fuel?
Old Sep 19, 2011 | 11:31 AM
kry226's Avatar
At least with the Fleetguards, that's why they changed the o-ring, which is now yellow to indicate the difference. Been using diesel to lube the o-ring for years now and not one leak or hiccup.
Old Sep 19, 2011 | 12:24 PM
Fiftygrit's Avatar
Baldwin filter and I just some diesel also to lube the O ring, never had a leak yet.
Old Sep 19, 2011 | 12:33 PM
ssandlin's Avatar
Another diesel fuel for lubricant user here, 115K miles and 11 filter changes with no issues.
Old Sep 19, 2011 | 02:03 PM
WEATHERBY460's Avatar
what filter do you recommend adn where to buy...thanks
Old Sep 19, 2011 | 02:10 PM
Fiftygrit's Avatar
I use the balwin think its PF7977 could be PH7977, I get it from truck shop Peterbuilt, they service cummins motors, about $12 bucks a pop, I always have 2 or 3 under my back seat.
Old Sep 19, 2011 | 07:23 PM
AH64ID's Avatar
The o-rings are designed for diesel.. If they couldn't work with diesel they wouldn't seal now would they.
Old Sep 20, 2011 | 08:30 PM
NavyDood's Avatar
I use Petroleum Jelly. AKA Vaseline...
Old Sep 20, 2011 | 08:42 PM
RamGazer's Avatar
10 Year Member
Thanks guys. I decided to go have someone else do it. Got my local lube place to do it for only $25 plus tax! I bought the filter from NAPA for about $22. If I had bought the filter from them and had them put it in they were going to charge me $130!!!! That's almost a 400% mark-up!!! Oink!!!!
