Fuel Filter Change on 2006
Old Jul 21, 2009 | 05:15 AM
gary4rv's Avatar
What size socket do I need, to change filter?
Old Jul 21, 2009 | 06:45 AM
D-Roc's Avatar
Use a 1 1/8".
Old Jul 21, 2009 | 08:34 AM
AkitaSumo's Avatar
it is also recommended to be a 6 point socket....
Old Jul 21, 2009 | 09:02 AM
billie's Avatar
And don't get too carried away with tightening it up again. Fully seated and firm is fine then check for leaks. Some get turned in way too hard.
The O-ring makes it turn out slow and resistive, its normal. Lube the O-ring (diesel fuel will work) when you replace it.
Old Jul 21, 2009 | 12:32 PM
ssandlin's Avatar
If you don't have a socket, use a crescent wrench (that's what I use).
Also, take some paint or fingernail polish and make a vertical mark down across the lid and onto the canister and let dry. Then after you remove the lid and replace the filter, you'll know to stop tightening when the paint mark on the lid lines back up with the mark on the canister.
Old Jul 21, 2009 | 01:50 PM
DBLR's Avatar
Make sure you use a filter that is 7 micron or smaller as Dodge and Fleetguard no longer want the 2003 an newer engines to use a 10 micron fuel filters that are still sold by many after market company's. Also make sure the filter you use can strip out water from diesel as not all filters claim in writing to do so. Many like my self use the 5 micron Baldwin PF7977, Donaldson P550800 or the 7 micron Fleet Guard FS19856.
FLYH2O
17
Sep 12, 2007 08:07 AM
vegashd
Jul 15, 2007 12:24 PM
Lunyfringe
Jan 10, 2005 05:40 PM
doitl8r
Jun 4, 2004 11:14 AM
XTOAK
17
Aug 23, 2003 09:07 AM
