fuel filter
Old Jun 6, 2007 | 11:07 AM
johndeere01's Avatar
fuel filter
hello,
I have a 04 cummins an i need to know how to change the fuel filter on it im pretty sure i can figure it out but i just figured i would ask
thanks dennis
Old Jun 6, 2007 | 12:06 PM
dodgezilla04's Avatar
dennis, welcome to dtr!
look at the top of the filter housing, you'll see the black plastic cover. either take a large adjustable wrench, or a 3/8's drive ratchet(square hole) and loosen the cap(counterclockwise). the filter is snapped into the lid and will come out when you lift off the lid. have a bucket handy to drop in into. open the yellow handled valve to drain the remaining fuel out of the bowl, close the valve. use a lint free rag to wipe out any remaining crud. you might see some small black dirt like substance(its algae and normal) install the new filter in the lid, replace the o ring on the lid and reinstall the lid. do not overtighten, just enough to compress the o ring slightly. bump the key to start to let the pump run for a few seconds. fire it up(it may hickup a few times until the air is out) while it idles, look for leaks.
Old Jun 6, 2007 | 01:32 PM
TexasCTD's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Here is a write up Horsehauler did a while back with pics. Hope it helps.
Welcome to DTR!
Old Jun 6, 2007 | 10:56 PM
mrblond's Avatar
what do you do with the drained contents of the bottle?
Old Jun 6, 2007 | 11:15 PM
DODGER BOMBER's Avatar
dump it in a oil waste bin or such. it is diesel fuel, but i might also have water and crud and such.
Old Jun 7, 2007 | 01:10 AM
jwb600's Avatar
when you get the filter out. put some clean diesel fuel in the housing. I have tried just cycling the key a few times and it was hard on the truck. I just put fuel back in with the new filter and it works good for me. I normally clean on the housing also with a rag. im sure this was stated somewhere else above
Old Jun 7, 2007 | 12:23 PM
thanks guys try it tonight
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
Lunyfringe
Jan 10, 2005 05:40 PM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
