Fuel in engine block!
Old May 18, 2013 | 02:22 PM
Creek Diesel's Avatar
Drained about 4-1/2...5 quart jugs of fuel/oil mix out of engine block. Suspect injectors letting fuel in all the time? Any one else had this problem?
Old May 18, 2013 | 03:14 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
you mean out of the waterjacket area? or just when changing oil out of the oil pan...
I suspect the later...
I would suspect injectors first off but there's thru-fittings in the head that could be the culpret too although unlikely. A crack in an internal injector line going from the feedthru to the injector could be to blame as well. In essence, any where fuel is present that a leak would allow it to go into the oil, is a potential spot to look at.
[ nice avatar pic Hiram ]
Old May 18, 2013 | 03:51 PM
Just when I dumped the oil. I have already pulled the fuel rail and getting ready to pull the injectors & internal tubes for replacement. [ thank you ].
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
plow
Dec 28, 2005 02:42 PM
1320
May 17, 2003 03:28 PM
