Fuel 3 psi
Old Dec 17, 2013 | 10:31 AM
AlCorr's Avatar
Fuel 3 psi
Went out this morning and only had 2-3 psi. I drove it to the store and back, no problem. It was cold last night and I'm due for new fuel filters, maybe some waxing on the dirty filters. Maybe it's my Holly Black fuel pump, it's been in there for about 5 years now and it looks like it is weeping a little on the bottom. I have a rebuilt Holly Black under the back seat. Not sure what to do?
Old Dec 17, 2013 | 11:43 AM
madhat's Avatar
Administrator/Jarhead
First, I would check the fuel line for the gauge, then change the filter(s). Dumping some PS silver in will help if you are gelling a little.
If you have fuel seeping around the pump, the seals may have worn, allowing fuel to get into the pump motor.
Old Dec 19, 2013 | 08:24 AM
carl48's Avatar
the cp3 will work and produce full power down to MINUS 5 psi lift pump pressure. the filters are ok. a plugged filter causes low pressure under load, not at idle. the stock in tank pump was the best but I bet you did not keep it. carry you a hose to bypass the pump in case the pump fails, you can bypass it and get back on the road then in the next few months get a brushless pump.
Old Dec 21, 2013 | 09:24 AM
AlCorr's Avatar
I installed a rebuilt Holly Black fuel pump, works good, at start-up it reads 20-21 psi, driving around town 17-18 psi, the highway 14-15 psi.
The pump I just took out was a used Holly Black and I got 4-5 years out of it.
I'm not sure if I should pick up another pump or try and rebuild this one myself. Anyone ever rebuild a Holly pump, any advise?
38 Cigarette
16
Aug 28, 2015 11:27 PM
schamran
Dec 14, 2009 08:20 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
