ft.lb torque
Old Dec 28, 2005 | 02:49 PM
markshop's Avatar
ft.lb torque
When did the cummins go from 600 to 610 ft.lbs of torque? What month exactly?
Old Dec 28, 2005 | 02:54 PM
markshop's Avatar
ft.lb torque
Old Dec 28, 2005 | 03:17 PM
Lrdchaos's Avatar
Don't know....but was wondering if you could even tell a difference in 10 lbs of tq? Also has anyone dynoed one of the 325\610 motors what do they put out rearwheel hp.
Old Dec 28, 2005 | 03:32 PM
bulabula's Avatar
What would you do if you knew an "exact" month?
Old Dec 28, 2005 | 06:23 PM
RamWheelsBy4's Avatar
2005 Cummins were suppose to be 610 torque rated. I did see early 2005 Cummins with the 600 rating. But most 2005s and up are 610 rated. Probably tweaked a couple of fuel map parameters just like the performance boxes or downloaders. But 10 pounds of torque would be hard to measure at the rear wheels on a dyno. All marketing, it was a "mine has more power than yours" thing.
Old Dec 28, 2005 | 06:50 PM
wap's Avatar
wap
Where is the tq rating? All I can find on mine is a HP rating.
Old Dec 28, 2005 | 08:28 PM
TurboTed's Avatar
Not that it matters, but I did notice that. HOWEVER- I can tell you that 20diesel HP & 45-55lbs. of tourque makes a H--l of a difference!!
Old Dec 28, 2005 | 08:41 PM
mikmaze's Avatar
mine changed from 600 to 610 when I did the flash what month was it? don't remember.
Old Dec 28, 2005 | 10:01 PM
Window Sticker:
DODGE RAM 2500 ST QUAD CAB 4X2
Exterior Color: Bright White Clear Coat Paint
Interior Color: Med. Slate Gray
Interior: Cloth 40/20/40 Split Bench Seat
Engine: 5.9L Cummins Turbo Diesel-610 lb-ft
Transmission: 4-Speed Automatic Transmission
STANDARD EQUIPMENT(UNLESS REPLACED BY OPTIONAL
Old Dec 29, 2005 | 01:23 AM
TexasCTD's Avatar
Mine too
I think it was in August of 04 or so when they came out with the 05's and made that minor change in the computer as a marketing thing against the Duramax engine when they marketed 605 ft lbs tq.
Dodge wanted to stay ahead of Chevy, so they made a minor tweak and called it 610.
If you have an 04.5 truck and get it reflashed...supposedly it is the same program.
Old Dec 29, 2005 | 01:36 AM
TexasCTD's Avatar
Prob August of 04 or so when they came out with the 05 trucks.
Old Dec 29, 2005 | 06:23 AM
markshop's Avatar
Thanks guys!
Just woundering what my 05 was.
Old Dec 29, 2005 | 07:47 AM
bigblock2stroke's Avatar
Thanks guys!
They are all 610's.
It was totally marketing. Cummins was delivering engines "centered" on 610 already ( to avoid low power complaints). There is no cal change whatsoever.
Centered is a term used to describe the average torque output of a batch/run of engines (like a tolerence, +/- 5 ft-lbs or whatever).
mitm
Aug 16, 2009 09:29 PM
Firstgenfanatic
May 14, 2008 06:17 PM
mainer
Jul 17, 2007 07:13 PM
PapaSmurf
Dec 19, 2003 02:14 PM
Davidp
Feb 1, 2003 05:49 AM
