Front wheel noise
Old May 22, 2011 | 09:26 PM
dogman's Avatar
Front wheel noise
I have developed a noise (click/clunk??) in the front wheels when the drive is engaged. More noticeable when turning the wheels at very low speed. No noise at all with front wheels disengaged. Truck has about 94,000 on it and has spent most of it's winter months in Florida so front wheel drive has been rarely used. Moved back to Pa. this past winter but didn't notice any problem until last week when the front was engaged to get through some mud. Now it's there every time I engage the front. What could be causing it?
Old May 22, 2011 | 10:04 PM
mini14's Avatar
sounds like your stub axle u joints. Did mine a couple of times.
Old May 22, 2011 | 11:57 PM
notw's Avatar
X2^^^ You will probably notice some rust just below the caps or even slop in the joint when you rock it back and forth. Check the wheel bearings and ball joints at the same time, there is a good chance they could be bad as well. There is a good write up here somewhere on ball joint replacement which will cover u-joints, ball joints and bearings if I remember right.
hush
14
Jun 10, 2007 11:53 PM
KWKING
Sep 27, 2006 03:59 AM
jetsnow
Sep 10, 2006 12:09 PM
Dodgezilla
Mar 30, 2005 06:00 AM
heavyg
Jun 24, 2003 07:43 AM
