front shaft knocking
Old Jan 10, 2014 | 02:51 PM
bishgeo's Avatar
Front shaft knocking again took it out last year and greased slip shaft fixed it for a while.Still has stock u joints dont know why theres no grease zert in shaft like the old ones.Deciding wheather to rebuild front shaft or just replace it.
Old Jan 15, 2014 | 07:35 PM
05doolie's Avatar
do yourself a favor and buy a new shaft..I just went through a lot of unnecessary grief with mine. I was getting a whirring noise from mine which turned into a vibration after I installed a leveling kit [only 2.5 inches] .
I removed it and took it to a driveshaft shop to balance and replace the universals I was told it was fine and was rebuildable.
175.00 later I reinstalled it and it vibrated so bad I had to remove it ! I took it back and after hearing how "good he is " and " never had a problem before " he rebalanced it and it was better, but I could still feel it at about 65.
I ordered one from Factory OEM Parts installed it and it is perfect.
Save yourself the grief..buy new and be happy the first time.
Old Jan 15, 2014 | 09:13 PM
BigIron70's Avatar
Cummins Guru
I agree by the time you price out parts and labor you can buy a factory new. I stopped rebuilding them for that reason. Make sure you use blue Loctite on the bolts.
The_Head
Jan 27, 2009 09:01 PM
louddodge
Sep 19, 2008 10:20 PM
masonpauls
Mar 6, 2008 10:06 PM
b.lee
14
Nov 18, 2006 09:28 PM
ramcummins
16
Jan 30, 2005 08:52 PM
