Front and rear diff questions
I have an 07 5.9 liter 2500 4x4 and I need to change the gear oil in both diffs. I have valvoline synthetic 75w140 would that product be ok to use and also what is the fluid levels for each differential I have had it done at the shop previous times but moved and don't trust a soul around here with my baby please help! Oh yeah and I don't know which rear end I have help on that would also be greatly appreciated!
yeah that fluid will be fine, the level your going for is about 1/4 of an inch below the fill plug, 8 quarts should do it (you could always return it if you don't use it all) and if your not doin it on a lift you might need to take off the LF wheel and disconnect the tie rod to get the cover completely off. Not positive though. You do have the 9 1/4 up front and 11 1/2 in back right? For future reference if you do have these axles the right fluid is syn 75 90 weight, 140 is a little overkill unless you tow heavy...
Yeah, a synthetic 75W90 rated GL-5 is what the book calls for.
On the rear end of some trucks (might have changed) there is "Fill Line___" stamped on the rear cover. The fill line is about 3/4" below the bottom of the hole.
Also the book says 24 ft lbs fill plug and 30 ft lbs cover bolts. There have been quite a few threads about broken cover bolts, so I wouldn't tighten them quite that much. On my 03 I did the first change at 30 ft lbs with no problems, so I thought maybe some had weak bolts and mine were fine, then the head twisted off one on the next change. It was hardly snug when it snapped.
afate45
Jun 7, 2014 12:08 AM
Bowser50
33
Jul 21, 2013 06:33 PM
banana
Dec 1, 2009 11:44 PM
SBRW
Jan 11, 2008 07:56 AM
shaft
13
Jan 29, 2004 07:37 AM
