front end hunting
Old Dec 15, 2014 | 10:57 AM
djdc's Avatar
front end hunting
Last month I had a case of the DW!
I knew the tires were on thier last leg so I threw down $1300 on a new set of Terra Grapplers G2. 285/75-17.
Now at highway speed ( 55- 75) the front end seems to constantly change direction or hunt or wonder.
I lowered the air pressure down from 70psi to 50psi in the front, 60 in the rear. Seemed to help some but I was worn out after a 400 mile trip.
I got 150K on the clock, all orignal parts, no lift, stock wheels.
Any suggestion?
Old Dec 16, 2014 | 08:25 AM
Steve-l's Avatar
Yes, something is loose(worn out). You need to get under the truck and put a jack under the spring. First on one side and then the other. Then rock the wheel up and down and left and right and look for something causing play. This is easier to do with two people, one doing the jerking and the other doing the looking. If you haven't changed out any steering parts at 150k, you're going to find lots of parts are worn out and loose.
Old Dec 16, 2014 | 09:20 AM
marder's Avatar
"Now at highway speed ( 55- 75) the front end seems to constantly change direction or hunt"
hmmm you mean dodge Cummins arent meant to do this? lol.
yeh @ 150' 000 its probably time to replace everything.
Old Dec 17, 2014 | 10:47 AM
djdc's Avatar
Well.... All 4 ball joints are rattling. I'd say 1/8" or better on each one.
Shocks, stablizer and tie rods seem ok tho.
Who make the best replacement parts?
I was thinking of using Moog.
Old Dec 17, 2014 | 02:41 PM
marder's Avatar
I dont care for moog. I put them on my 96 when I had it and after about 2000 miles it was like I had never replaced them. I was right back where I started. I have XRF on my 05 and I like them. They are greasable too.
chadwick
Apr 27, 2013 10:04 PM
1999blackcloud
Jan 26, 2010 08:52 AM
Gordonville
Apr 18, 2005 09:45 AM
royta
Jul 13, 2004 06:54 PM
