-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Front axle u joint replacement trouble!?!? (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/front-axle-u-joint-replacement-trouble-238322/)
mattyfz450 Mar 26, 2009 07:47 PM
Ok so i am in the process of replacing my front axle u joints (wheel joints). So far i have removed the tire, brake caliper, disk brake, and loosend the 4 bolts on the back side. and now i can not seem to get the hub and bearing separated...i have tryed using the socket and extention with no luck ( i may be doing it wrong if anyone can refresh my memory on exactly how it is done and which bolt to put the extention on i would appreciate it). i am also not sure what kind of puller will work. And do you have to remove the ball joints also??? if anyone can point me in the right direction i could really use it.
ptm600 Mar 26, 2009 08:14 PM
Here is a link to MR.GADGETS write up on how to do it. This should answer all of your questions, if not ask again.
Paul
https://www.dieseltruckresource.com/...d.php?t=217250
booman70 Mar 26, 2009 08:46 PM
use lots of pb blaster or your favorite penetrating oil
mattyfz450 Mar 27, 2009 06:15 AM
after the hub and bearing is separated will the axle and u joint fit through the hole in the spindle where the bearing came out of ? i havent got the bearing separated yet but it seems like even when i do that the axle and u joint wont fit through the spindle, but im probably wrong?
booman70 Mar 27, 2009 08:03 AM
yes it will fit
